First, Happy Thanksgiving to one and all. After you celebrate Thanksgiving with family and friends please ponder this.
I think I am finding out why it takes forever to start my TR3 even while spraying starting fluid into the carbs while turning it over hoping the battery and starter hang in there. Plenty of fuel. I am becoming it is an ignition spark problem as I finally removed the number 1 wire and put
a spare plug in there and layed it on the valve cover. There is a spark but it is a very anemic looking spark to me. I am no expert on healthy sparks but this looks like it is barely making the gap. No pop...no sizzle to say the least. So I have done some swapping with the ignition system. New condenser, tried three different coils all of which have worked at on time or another and as far as I know should be working now. Changed points. Set gap and reset it. Dwell is 49 degrees which sounds close to me. I have taken apart the distrib to clean up the advance weights and springs. Put it back together being as careful as I can be with the wire connections. Ground wire in distrib given extra attention. Here is my first question, finally, if you look at the jpg file I have attached you see both the red wire coming from the coil and the black wire from the condenser connected together at the top of the points post. I am wondering if they should be seperated in that one should be at the top of the post (but underneath the plastic
deal) and the other below, on top of the other plastic thing. Why else would they go to so much trouble by putting
those plastic things at the top and the bottom?
The other thing that puzzles me is that I cannot measure ANY
resistance between the postive and negative posts of ANY of my three coils. It measures 0 on all. I thought it was supposed to measure either 1.5 or 3 ohms. I vaguely recall
fooling around with my motorcycles coils and measuring something as resistance. Could I have 3 bad coils? If I do
could I have something messed up on the car that fryed all three that I ought to hunt around for? It is hard to believe that all three are bad but it is clear that all three measure absolutely 0 resistance. I don't know whether this is here or there but if I measure from one post, either
positive or negative, to the center where the big wire goes to the top of the distrib, I do get resistance. 9.9, 7.1 and 8.7 ohms for each one.
I would love to just by a coil and have a big healthy, snappy spark but I am really wondering if I have a coil killing machine right now and would be just throwing away another $20. Last kind of interesting fact is that I can start up and run my black beauty but only after three and sometimes four rounds of starting fluid squirts into the carbs, with or without the air filters. Each failed round runs exactly as long as the starting fluid does. Then finally it will run by itself and I can ride around. It runs pretty well too except under load. Huge bog and sometimes backfiring. The bog on acceleratioin I can pretty much count on. Last bit of information. My charging system
is not charging. I plan to take care of that by doing an alternator conversion tomorrow. For now I am charging the battery every night. It charges up to 14.5 volts....so far.
Thanks very much and have a Happy Turkey Day.
Jim Lee
Jim Lee
