Spark Plugs
SaxMan
After dealing with dozens of distractions (all good distractions, mostly related to bicycle stuff and some of my writing / historical research) that have kept me away from my Sprite (and from BCF, for that matter), I finally pushed everything aside and said "It's time to work on the Sprite". Nothing crazy for the winter maintenance, just a general going through everything to get it ready for another season of Dad / Daughter adventures.
I pulled my plugs to replace them. Cylinders 1 & 2 had rather normal looking wear on the electrodes, although there was carbon around the ring. Cylinders 3 & 4 were more sooty on the electrodes. All were a little bit oil fouled, but that's been an ongoing issue. I'm thinking the carb mixtures are off? Just not sure what would cause that kind of variation in wear.
On the upside, the Seafoam treatments seem to be helping to keep the motor going until I can pull it and rebuild. Cold compression has moved up 15 psi from 150 to 165 on my low cylinders, and my high cylinders are (1 and 4) are 172 and 168. That may also be me getting better at making the valve adjustments.
NutmegCT
Seafoam worked wonders on my TR3 engine. I did the "one tablespoon of SF in each cylinder, soak overnight" technique. Got all four cylinders nearly equal in (good) compression.
Assuming you have a single carburetor, have you checked the gap for each plug? And that the plugs all go down the same amount when threaded in? I found one plug on my Nash, which had three (!) washers in the hole, instead of one.
Also, I'd suggest driving about ten miles, up and down hills, and then re-checking the plugs. As you say, you've been away from the Sprite for a while. Crud can build up in lines, which a good drive might clear.
Tom M.
S
SaxMan
I have the dual carb setup. I'll hit the cylinders directly with the Seafoam and see what happens. Probably would make sense to pull the plugs for inspection on a regular basis to see where things are going.
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
tahoe healey Spark Plugs Austin Healey 20
G spark plugs Austin Healey 10
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Simon TR4a TR4/4A Spark plugs, what do you use? Triumph 4
gbtr6 TR6 What spark Plugs do you use? Triumph 1
S MGB 1969 MGB No spark to plugs MG 5
R Spark plugs for 61, BT7 Austin Healey 2
M TR4/4A Spark plugs. Triumph 1
T TR4/4A What gap on Champion L-87YC spark plugs? Triumph 3
sim Dead spark plugs ? Spridgets 52
tinman58 General Tech Bad spark plugs Triumph 7
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
S TR2/3/3A TR3A Spark Plugs Triumph 4
JPSmit How often do you change your spark plugs? Spridgets 7
R Mixing spark plugs Triumph 10
B Spark plugs with Webers Austin Healey 6
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
K TR4/4A NGK Spark plugs BPR5HS for TR3A/TR4A Triumph 3
Flash_Harry Any thoughts on these spark plugs? MG 9
B Spark plugs Austin Healey 3
M Spark Plugs!!! Triumph 13
D Read Spark Plugs Spridgets 21
fad64b NGK Spark Plugs Triumph 2
JodyFKerr Fighting with spark plugs in an Explorer Other Cars 19
Randy Forbes Platinum spark plugs...? Austin Healey 7
Musicman Spark Plugs - Champion or NGK Triumph 13
SkinnedKnuckles Lasers to Replace Spark Plugs... Triumph 1
S Spark plugs Triumph 20
M 100M spark plugs Austin Healey 2
TR6oldtimer Reading spark plugs as a tuning aid Triumph 19
R Compression/spark plugs Spridgets 13
TR6oldtimer TR6 TR6 spark plugs Triumph 7
Grampy spark plugs Racing 2
A no spark to plugs!!! Triumph 20
C Best Spark Plugs for BJ8 Austin Healey 14
texas_bugeye Spark plugs Heat range Ethl blended fuel Spridgets 6
Stinger TR4/4A TR4A Spark Plugs Triumph 8
