TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter....
karls59tr
Bronze
than the regular plug for the Tr3. What affect would running this plug in an engine with new ignition parts and the carbs set up properly?
Keoke
AS long as they agree with your regular plug's dimensions and the heat range for your engine or the fuel type you use they should be fine.Most LBC users prefer them.
K
karls59tr
Bronze
This plug is not the correct heat range for this engine but is a " hotter" plug. I just wondered what the affect on the engine would be if any?
sp53
I have used them with no problem. I think the 5 series ishotter than the 6 when it comes to NGK. These cars were made at a time whengasoline was higher octane anyway. My experience has been that the plugs needchanging more often anyway, so it is difficult to tell a plugs true lifetime. Somestuff that will help the plugs are metal plug wires and top quality fuel. A qualitycoil helps a lot also. Some of the stuff today is real crap. I bought a lucuscoil that lasted a week. You can get good substitutes that work well that fitcars from the 60’s
Keoke
Sometimes in a worn engine a hotter plug will improve the engines performance. Just have to try it and see.
CJD
The up-side to a hotter plug is less carbon fouling of the tip if you frequently go for short drives, so the fuel mixture is richer for a higher percentage of your drive. Lots of city driving with long periods idling is another time the hotter plug will be less likely to foul.
The down side is it could cause "pinking" when the engine is fully warmed up and being driven hard. So it may require a slight reduction in timing advance. If all your driving is freeway, a cooler plug may be advantagious.
Of course, both of these statements are generalities. Your driving pattern makes all the difference in proper heat range. The goal would be the coolest heat range that does not cause fouling.
K TR4/4A NGK Spark plugs BPR5HS for TR3A/TR4A Triumph 3
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
longbridgehealey NGK plugs Austin Healey 23
fad64b NGK Spark Plugs Triumph 2
Musicman Spark Plugs - Champion or NGK Triumph 13
K TR2/3/3A Next hottest plug from NGK BP6HS on a TR3? Triumph 4
G Bad NGK plug Triumph 2
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
K Numbered Spark Plug Boots? Austin Healey 27
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
Sopwith_Camel MGB the mysterious disapearing spark MG 21
