Mixing spark plugs
ragtop
The plug in my #5 cylinder fouls up after about 250 miles or so. At that time the engine starts missing slightly and I clean it off and it runs great for another 250 or so miles. Its an oily deposit. Would installing a hotter burning plug in the one cylinder help this out? Can I just place a hotter burning plug in one cylinder and keep regular plugs in the other 5 cylinders? The engine/valves have never been rebuilt and other than this issue the car still runs fantastic. And yes it does blow some blue smoke more so till it warms up. Chris - 69TR6
TR3driver
Great Pumpkin - R.I.P
Yup, you can use a hotter plug in just that one cylinder.
Another old time trick that might be worth trying is to file away the end of the ground electrode, so it only covers about half of the center electrode. I don't know why it works, but "2-cycle" plugs used to come that way.
I'd also try running Valvoline synthetic motor oil for at least one oil change. Might not make any difference, but it has cut oil consumption on several engines for me. (Unfortunately not the TR3.)
LarryK
Some mechs have put in Ford valve seals which do stop the oil from fouling the plugs. Can be done without removing head.
TR3driver
True, but that only works if the oil is getting through the intake valve guide. Given that it seems to only be #5 with a problem, plus it gets better as it warms up, I'd guess that the oil is coming past the rings. In which case adding valve seals won't help at all.
Easy way to tell the difference is ask the driver following you to watch when the tailpipe smokes. If it blows "puffs" every time you shift, then it's a valve guide problem. If the worst smoke is when you are on the throttle, then it's rings (or cylinder wall).
poolboy
What spark plug are you using ?
Before I overhauled my 74 TR6 engine, I was using a quart of oil per 400 miles and never fouled a Champion RN12YC spark plug.
pdplot
I once had a Twin Cam MG that I bought new. It consistently fouled plugs from the day I bought it. My solution? I actually had 3 heat ranges in 4 cylinders. As I recall some 44 years later, I had 2 N3s an N5 and an N8 Champion plugs. I got calls from Twin Cam owners as far away as Washington, DC asking me how I got mine to run without plug fouling. BTW, I only kept the car for about 6 months before trading it for a VW Beetle sunroof - but that;s another story..
R
ragtop
I've been using NGK BP6ES plugs. I've got a RN12YC that I'll put in today. Thanks for all the responses - Chris
BillyB62
I had the same problem with the NGK plugs - switched back to Champion and the car runs great again.
R
ragtop
Does everyone stick with the recommended 0.25" gap? I sort of remember folks using a gap of .30" for some plugs. I went ahead and put all new 12YC plugs in at 0.25" and the engine is missing just a wee bit and it wasn't before. The NGK plugs I pulled out measured closer to 0.30" - Chris
Crankshaft
Since I am the poster child for Murphy's law, I have had the opposite experience. I could not keep Champions from fouling. I switched to NGK BP5HS, which is one step hotter, set them @ .030 and have ended my fouling problem.
mrv8q TR2/3/3A Mixing MT-90 with Hypoid Gear Oil? Triumph 13
TRMark Body Filler Mixing Board on the cheap Restoration & Tools 2
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
T Mixing one and two post fulcrum brackets Triumph 3
B Mixing autobody products? My 2 Pence Restoration & Tools 0
T mixing oils Austin Healey 6
Webb Mixing Brake Fluid Spridgets 16
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
K Numbered Spark Plug Boots? Austin Healey 27
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
