Mixing Brake Fluid
Webb
I've heard rumors that mixing DOT3 fluid and the old Castrol Mineral based fluid will eat up seals and things in British cars. However, it seems many members just put DOT3 in, and I doubt most have flushed their whole system. Is this mixing safe?
jlaird
My understanding is that Dot 3 mixes with anything.
Speedy_Pete
Haven't tried mixing fluids, always been told to keep it the same. With summer coming it's a good time to get the system bled through so it's ready.
Webb
Webb
This is the supposed mineral based fluid I've been using. Perhaps you recognize it or use it? (Click for larger picture)
vping
Bronze
LMA is what I have been told we should be using in our LBC's
jlaird
Ahhh, the good stuff.
Webb
Webb
Yeah, it's hard as heck to find. I have to drive an hour and a half to get it. Anyway, is that stuff safe to mix with DOT 3?
Morris
My friendly neighborhood Advance Auto stocks LMA at a decent price. But I use "synthetic" Dot 4, personally.
racingenglishcars
Since the 70's that I know of, DOT 3's are mixable. That was one of those DOT rules they inflicted upon the manufacturers. That's why Castrol went from the "Girling" to the "GT-LMA" (low moisture action)
I would therefore say yes, OK to mix with other DOT-3's... but, you know there are always different experiences, opinions and data.
Just don't mix with DOT-5. That is Silicone.
jlaird
As I remember right there on the bottle it says it is ok to mix but for the old mineral oil kind which has not been available for 20 years or so.
R
RonMacPherson
Synthetic Dot 4?????
Somebody sold you ONE weird container of brake fluid.
Dot 3 and Dot 4 are both ester based fluids, just refined a different way) Dot 3 and Dot 4 only have different boiling temps, different hygroscopic resistances.
Dot 5 is synthetic. Doesn't eat paint, very slight compressability(which you are NOT going to be able to detect in a street vehicle, properly bled). Dot 5.1 is another nest of worms.
Dot 5.5 is back to a synthetic blend but reportedly the latest and greatest as it is supposedly non harmful to some of the seals and "rubbers" that are used in braking systems. But 5.5 is hard to find. You may be able to get your friendly parts store to order it for you, but good luck.
Healeysince59
Valvoline makes a synthetic that "meets and exceeds DOT 3 and DOT 4 requirements". I have used it with good results for years. It is generally considered DOT 4. It is not DOT 5. DOT 5 is silicone and controversial.
Marv James
Morris
Yeah, "synthetic" is just marketing crap. It's just highly refined DOT 4 that has lower moisture absorption properties and a higher boiling point.
BTW... "Synthetic" Castrol is not synthetic either. It too is just highly refined conventional oil.
mrv8q TR2/3/3A Mixing MT-90 with Hypoid Gear Oil? Triumph 13
TRMark Body Filler Mixing Board on the cheap Restoration & Tools 2
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
R Mixing spark plugs Triumph 10
T Mixing one and two post fulcrum brackets Triumph 3
B Mixing autobody products? My 2 Pence Restoration & Tools 0
T mixing oils Austin Healey 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
