Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Mine is black. Sheen is a big harder to say after more than 50 years so I can only guess at that. My guess would be a semi-gloss that is somewhat glossier than modern 'satin' finishes.
Water Pump and Pulley and Fan Belt. No changes (ref: SPCEd4, pg. 9). The water pump, body, and pulley
may be left unpainted or painted black. A grease nipple should be installed on the upper RH of the pump.
Thanks for the info. I looked at several photos on the net and concluded black. No hole for grease nipple on the new one, although the casting retains the boss for it.
Bob
The replacement pump on my TR3A did not have a Zerk so I cut the threaded end off of one, flattened the end on the grinder and JBWelded that piece to the boss on the pump.
My apologies in advance to the future owner who tries to grease the pump with that Zerk.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
