Wow it's been a long time since I've been over here and I can see I have a great deal of reading to do to catch up.
Have a question for you: When you "seat" the ball on an overdrive is it just to insure the top hole is closed or both the top and two side holes on the plunger. Hubby is working on mine right now and the top is seated perfect but we can see a tiny bit of light from the holes on the side when we hold a light to the other side of the plunger. Oh the solenoid works fine and pushes the ball all the way to the top and seals the top hole. It's on a test bench right now. Don't want to put it all back together, fill with oil, etc., before we know about those two side holes
Your turn
Your turn
