Hey all,
Still working on my overdrive - that Healey 5 speed is looking better every day ! Anyway, could someone tell me proper way to "seat" the ball bearings for the oil pump and operating valves ? Know it says to "gently tap the ball bearing into its seat with a copper drift" but how do you tell if it is "seated" ? I have had both apart and know I did not seat these two ball bearings with a copper drift or anything. Basically pushed the oil pump ball bearing into place and simply dropped the operating valve one into the access hole. And works great when cold but as everything heats up to full operating temp, lose oil pressure and OD stops working. I've posted lengthy posts about this previously so will not bore all with repeating here. Can you use a piece of soft wood as I think I have read instead of the copper drift ? And is a copper drift just like a nail punch but made of copper ? All advice will be very appreciated
Thanks,
Mike
Thanks,
Mike
