Proper oil?
M
Member 10617
Still a little confused about this one. In 1960 Bugeye Sprite, should I use 20W/30 engine oil in engine and transmission (as handbook suggests) or 20W/50 as some members of this forum have suggested. Or does it make much difference.
Getting ready to change my oil....
Thanks.
Ed
59diamond
I use 20W/50 in my 1960 Bugeye for the engine which is a 1275 and 90 weight in my transmission which is a Datsun 210 5 speed.
I use Valvoline racing oil that I get at O'reileys
M
Member 10617
59Diamond and Desert Rat:
Many thanks. I'll use Castrol conventional oil 20W/50 in my engine, and since I have the originall transmission, I'll use it in the transmission as well.
Again -- many thanks for the advice.
Ed
P
Paul McGuffin
From what I’ve read, Valvoline had the highest ammount of zinc. I use Castrol 20/50 in both. I also mix 20% Lucas in the engine, trans and rear differential.
DugMoney
Member
I use Pennzoil HD 30. I also add STP oil treatment in as well. This would be for changing the oil...I also use FRAM oil filters.
Got_All_4 TR2/3/3A Which oil cap decal is proper to use with this cap Triumph 7
M What is the proper oil for Bugeye engne and transmission Spridgets 6
A Proper Gear oil? Triumph 9
brgrmyster GT6 Proper stock color oil filter canister 68 GT6? Triumph 7
af3683 TR2/3/3A Proper Oil for TR-3 Steering Box Triumph 22
A Proper Oil Filter MG 22
RJS Oil Pressure Relief Valve - Proper Function Triumph 2
T Proper Engine Oil Temperature? Triumph 2
T TR2/3/3A Proper oil TR3 Transmission Triumph 3
R TR6 Proper alignment of gearbox front cover plate Triumph 3
sundown TR6 Proper ring gaps Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
M Proper running temp for 1275 Spridgets 28
Bob_Spidell Proper Engagement of Overdrive Austin Healey 8
M Hauling a Spridget - Proper tie down technique? Spridgets 15
M Choosing the proper inner tube Spridgets 6
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
KVH TR4/4A Proper Ring Gap Triumph 4
bugedd Fuel Leak and Proper Routing Spridgets 9
M '69 Sprite Proper Seats Spridgets 3
R Proper Timing Technique '60 BN7 Austin Healey 0
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
britlover proper tire size to replace 5.90-15? Austin Healey 16
Got_All_4 TR2/3/3A Is this the proper Boot lid seal? Triumph 9
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
J TR2/3/3A Proper distributor for 1960 TR 3A Triumph 5
K Proper SU Adustment Austin Healey 16
T proper jump starting technique Austin Healey 2
F Proper location of chrome loop for spare tire strap? Austin Healey 2
M Proper torque for cylinder head nuts Triumph 20
R proper antifreeze? Spridgets 2
B MGB Proper MGB Overdrive speedometer MG 3
brgrmyster Proper finish on luggage floor angle assembly? Triumph 0
M Restoring proper order to spark plug wires Triumph 36
M Proper use of the Gunson Colortune Triumph 41
G Proper Torque for Water Pump Install MG 4
tri_carb_healey brake drum work, proper jack points Austin Healey 12
tri_carb_healey proper type of gasoline Austin Healey 6
bighealeysource Pics needed on proper way to fold up top on BN2 Austin Healey 1
M Proper Brake Fluid For 1960 Morris Minor Pick Up Spridgets 8
J Proper brake fluid Austin Healey 19
af3683 TR2/3/3A Proper Use of Jack Stands on Rear of TR3B Triumph 9
M Proper servicing of overdrive Triumph 15
M Proper use of British Crimping tool Triumph 21
M TR2/3/3A Proper servicing of TR3 air filters Triumph 20
T proper use of exhaust clamps Austin Healey 11
rggav Proper way to remove and reinstall wire wheels? MG 6
pjsmetana Spitfire Proper Jack Points? Spitfire Triumph 8
H Proper Installation of shock mounting plate Austin Healey 3
