UPDATE: I have just received an email from British Wiring with instructions on how to use the British Crimping tool I purchased from them, and I will share the information with you.
"The first thing you need to make sure is that the bullets you are using are crimp-able. There are some bullet connectors that are not designed to be crimped, and must be soldered.
The hexagonal cut-out on the tool that is marked "crimp here" is where you place the collar of the bullet to crimp. It does not matter which direction the bullet is placed. The only reason one side has a larger hole than the other is that the one side needed to be machined out to get the proper width crimp.
You will need to strip 1/4" of insulation off the wire. Slide the wire into the bullet. Place the bullet into the crimper, and close the tool. When you crimp, you squeeze the crimper together until it unlocks (it will click multiple times) and releases the bullet.
The shape of the bullet will not be affected when you crimp the bullet properly."
.... And so, this seems to be all that we need to know, except how to tell a crimp-able from a non-crimp-able bullet...
UPDATE to the UPDATE. I have followed the British Wiring instructions and the crimping tool cuts the top of the bullet completely off each time??? Any thoughts on this? Are Moss bullets non-crimpable?
I am using Moss 162-200 Wire Tip, solder type bullets. It appears that these, which are the only ones Moss supplies, are non-crimpable.
UPDATE to the UPDATE to the UPPDATE (!). I just called Moss and the technician there says that Moss wire tip, solder type bullets (162-200) cannot be crimped. They sell a solderlsess one that can be crimped but it cannot be soldered. So, I wonder what bullet those of you are using that can be both soldered and crimped? Moss technician says that soldering is sufficient for the 162-200 bullet.
