Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
The compression and scraper rings on my AE pistons are showing .018 gap. The pistons seem fine. They're AE. Should I just get new rings and file them to spec, or do I need to check the sleeves (somehow)?
Given that your engine seems very fresh otherwise (indicating it doesn't have a lot of miles since being rebuilt), I'd call this another example of premature ring wear possibly brought on by use of E10. You might want to consider using an upper cylinder lubricant (eg Marvel Mystery Oil) with the new rings. Steve Hedke (former owner of British Pacific) saw the same problem with quite a few vintage engines (including a club member's TR4 and a flat head Ford); I got the MMO idea from him.
Burning oil, excess blowby, poor power, poor compression readings. When Bob's TR4 had the problem, he was blowing a steady stream of blue smoke whenever he was on the throttle.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
