proper antifreeze?
recordsj
what is the proper antifreeze to use in our cars (I personally have a 1500 MG midget)?
The shop manual says SAE J1034, but I haven't found an antifreeze with that specification.
PAUL161
The traditional green antifreeze. Same thing I've been using for 56 years. I buy the pure stuff and dilute my own for our temperature zone. If you buy the 50/50, so called antifreeze coolant mix, your paying a high price for half a jug of water.<span style="color: #009900">(Not to confuse with the industrial grade</span> <span style="color: #009900">antifreeze/coolant)</span> designed for industrial engines. I change the coolant in my cars and trucks every two years. I take my old coolants and oils to a processing center. PJ
Billm
No idea just what that spec is but it probably isn't available any more anyway (if it ever was in this country).
Do as Paul said and use the green stuff.
BillM
R TR6 Proper alignment of gearbox front cover plate Triumph 3
sundown TR6 Proper ring gaps Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
M Proper running temp for 1275 Spridgets 28
Bob_Spidell Proper Engagement of Overdrive Austin Healey 8
M Hauling a Spridget - Proper tie down technique? Spridgets 15
M Proper oil? Spridgets 6
Got_All_4 TR2/3/3A Which oil cap decal is proper to use with this cap Triumph 7
M What is the proper oil for Bugeye engne and transmission Spridgets 6
M Choosing the proper inner tube Spridgets 6
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
KVH TR4/4A Proper Ring Gap Triumph 4
bugedd Fuel Leak and Proper Routing Spridgets 9
M '69 Sprite Proper Seats Spridgets 3
R Proper Timing Technique '60 BN7 Austin Healey 0
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
britlover proper tire size to replace 5.90-15? Austin Healey 16
Got_All_4 TR2/3/3A Is this the proper Boot lid seal? Triumph 9
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
J TR2/3/3A Proper distributor for 1960 TR 3A Triumph 5
K Proper SU Adustment Austin Healey 16
T proper jump starting technique Austin Healey 2
F Proper location of chrome loop for spare tire strap? Austin Healey 2
M Proper torque for cylinder head nuts Triumph 20
B MGB Proper MGB Overdrive speedometer MG 3
A Proper Gear oil? Triumph 9
brgrmyster Proper finish on luggage floor angle assembly? Triumph 0
M Restoring proper order to spark plug wires Triumph 36
M Proper use of the Gunson Colortune Triumph 41
brgrmyster GT6 Proper stock color oil filter canister 68 GT6? Triumph 7
G Proper Torque for Water Pump Install MG 4
tri_carb_healey brake drum work, proper jack points Austin Healey 12
tri_carb_healey proper type of gasoline Austin Healey 6
bighealeysource Pics needed on proper way to fold up top on BN2 Austin Healey 1
M Proper Brake Fluid For 1960 Morris Minor Pick Up Spridgets 8
J Proper brake fluid Austin Healey 19
af3683 TR2/3/3A Proper Use of Jack Stands on Rear of TR3B Triumph 9
M Proper servicing of overdrive Triumph 15
M Proper use of British Crimping tool Triumph 21
af3683 TR2/3/3A Proper Oil for TR-3 Steering Box Triumph 22
M TR2/3/3A Proper servicing of TR3 air filters Triumph 20
T proper use of exhaust clamps Austin Healey 11
rggav Proper way to remove and reinstall wire wheels? MG 6
pjsmetana Spitfire Proper Jack Points? Spitfire Triumph 8
H Proper Installation of shock mounting plate Austin Healey 3
P TR2/3/3A Proper screws for a TR3A interior Triumph 4
A Proper Oil Filter MG 22
6 Whats the Proper Way to Remove Tie rods on AH BJ8? Austin Healey 17
RJS Oil Pressure Relief Valve - Proper Function Triumph 2
