Ball Joints and Mini ID
King_of_England
Hi,
Sorry I tried to search this but came up short other than I think it is from a MG Metro………………… I have a '72 clubman with a later motor and front end... When I order parts I am confused on what year parts I need.... Like ball joints....etc.... My engine number is 12HC04AA # 100936 ...Can anyone tell me what year car this came out of.....or any info would be appreciated?
Thanks bunches
Gary Maue
dklawson
Basil doesn't like it when I refer people to other sites but in this case it is justified.
I believe you'll find a FAQ or pinned thread somewhere on MiniMania.com that will explain decoding cars by their VIN numbers. I think that same thread discusses engine numbers.
Unfortunately, if your front brakes/hubs are from a Metro the ball joints will be different and your Clubman VIN won't help you there. I wish I could tell you how to tell the difference between the two ball joints but I have only seen the Mini parts.
Deleted member 8987
Yeah, the 12H had me puzzled, as one of my MG sources doesn't show an HC.
However, another source shows two 12H series in Minis, but it also shows a 12HC as Metro 1300 1275cc, series 12HB, 12HC, 12HD, 12HE,12HF.
Metro front end fit under your Clubman?
Metro 1300's produced 1982 - 1990
Didn't the Metro use Mini powertrain?
dklawson
Powertrain... yes. Front hubs/brakes, no.
It's pretty common to find Metro engines transplanted into Minis and there was a time when it was very common for people to adapt the Metro front hubs and brakes to the Mini as well. I don't know the specifics, but there are apparently some significant differences that can lead to undesirable geometries when the Metro hubs are used on the Mini. Sorry, I wish I could be of more help.
King_of_England
King_of_England
Yep, I believe the metro front end is what I got... disc brakes and all....
But I'm not sure of the year????
Thanks bunches 4 your time
Gary
King_of_England
King_of_England
Thanks to all....
I have the complete metro set-up with all adjustable rods arms etc etc... I should have known that when the disc rotor was different.. When I bought it had 12" wheels... I switched to 13".... Just had it all aligned.... it drives beautiful...
Going a couple hundred miles over to coco beach for the mini spring thing next week....
dklawson
Enjoy yourself at Spring Thing. I'm too much of a lightweight to consider driving my Mini that far. Several years ago a friend of mine drove from here to there... but he's the adventurous type! I can't stand the idea of 12+ hours in a car running 4k RPM.
D TR4/4A TR4 inner ball joints Triumph 8
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
M Broken Ball Joints Spridgets 14
Tabcon Ball Joints and mushy rubber Triumph 7
bigjones Ball Joints - does this look right to you? Spridgets 12
mrv8q TR6 TR6 carb "ball joints" Triumph 10
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
A TR6 Jag ball joints donot work on TR6!! Triumph 5
V TR6 A TR6 with Jag ball joints Triumph 27
S S-Type Bad Ball Joints, Control & A Arms Jaguar 19
KVH Tie Rods and Ball Joints Triumph 5
S Wedge Ball joints on TR7 Triumph 7
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
Joe Reed General MG MG logo ball point pens... MG 0
D TR4/4A inner tie rod ball joint tension Triumph 0
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
Keith_M steering rack inner ball joint Spridgets 14
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
D Side Rod Ball & Joint Installation Austin Healey 17
S TR2/3/3A this shifter/ ball and cup Triumph 5
W Etype lower ball joint removal Jaguar 14
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
T sourcing linkage ball/sockets Austin Healey 13
J New Ball Joint for Control Arm or use the old one? Triumph 4
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
T Help on ball joint - vertical link fit Triumph 20
doughairfield Ball joint to spindle Triumph 3
Mark_Barton Ball bearing in Float Chamber? Triumph 8
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
T TR4/4A Silly question on TR4A ball joint Triumph 4
CinneaghTR Which ball joint separator should I use? Triumph 7
S TR2/3/3A tr3 ball studs Triumph 8
Tabcon New Ball Joint Install Help Needed. Triumph 2
A fuel line ball valve - are they available Triumph 4
SilentUnicorn Ford-93 ranger Ball Joint-lower 4x4 Other Cars 2
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
J Ball joint and steering question Triumph 12
KVH Ball Joint and Tie Rod Grease Zerc Fittings Triumph 4
bigjones Upper Ball Joint Fun and Games Triumph 15
