New Ball Joint for Control Arm or use the old one?
Jerry
Group,
661-070 the ball joint that connects the control arms on the TR3-early 4. I am arguing with myself on if I need to replace these in my rebuild. I don't know how to test them other than we know they are original to the car. Do they wear that much and do YOU replace them in your restorations? MOSS just happens to have them on sale, so I was considering the purchase.
Jerry
TR3A
CJD
Fairly easy. When you move the ball stud around by hand it should be difficult to move. If it is easy, or rattles, it's shot.
Also check for binding as you move it, as the ball can wear a notch so it is only worn at one spot. It will feel notchy if that happens.
waltesefalcon
:eagerness: What he said. Only replace them if you need to.
KVH
The question is a good one. Folks here sometimes worry that the new ball joints aren't as good as the old ones. I really hope that's not the case, though we all know how world has changed. For me, I remember when the ball joint on my dad's car broke while I was driving. The thought of that happening at any appreciable speed isn't a good one.
I tend to agree it's a judgment call, but if you engaged in any major pounding and effort to get the old one off, or it feels loose, I'd replace it.
Don Elliott
If the rubber boot is not cracked or gone to jelly, it's possible that the grease is still inside and this would have kept sand and other grit from getting to the bearing surfaces inside. If you swivel it and it doesn't feel gritty, then re-use it.
During its first life up to 80,350 miles, I rallied my 1958 TR3A extensively from 1959 to 1965 - mostly on gravel and sandy roads. So when I did my restoration from 1987 to 1990, I replaced the ball joints. They have been there since then and I've had no issues with the 1990 repros which have accumulated 110,000 miles since 1990.
But I had to change the rubber boots at least twice because the repro rubber goes to jelly. Fot the past 4 or 5 years, I have been using red Amsoil synthetic grease to see if the repro rubber boots are attacked or not by the new red grease. So far, so good.
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
D TR4/4A inner tie rod ball joint tension Triumph 0
Keith_M steering rack inner ball joint Spridgets 14
D Side Rod Ball & Joint Installation Austin Healey 17
W Etype lower ball joint removal Jaguar 14
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
T Help on ball joint - vertical link fit Triumph 20
doughairfield Ball joint to spindle Triumph 3
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
T TR4/4A Silly question on TR4A ball joint Triumph 4
CinneaghTR Which ball joint separator should I use? Triumph 7
Tabcon New Ball Joint Install Help Needed. Triumph 2
SilentUnicorn Ford-93 ranger Ball Joint-lower 4x4 Other Cars 2
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
J Ball joint and steering question Triumph 12
KVH Ball Joint and Tie Rod Grease Zerc Fittings Triumph 4
bigjones Upper Ball Joint Fun and Games Triumph 15
S Greasing new upper ball joint? Triumph 5
C Turning ball joint Triumph 6
M TR4/4A TR4A upper Ball Joint Removal Triumph 9
J Spitfire Ball Joint replacement on Spitfire Triumph 1
M Ball joint/tie rod ends Triumph 8
M XK 140 Lower Ball Joint Jaguar 1
S TR2/3/3A Tr3 ball joint play Triumph 2
C TR2/3/3A TR3 Ball Joint Replacement Triumph 2
Guinn Ball joint problem!!! MG 4
S tie rod end/ ball joint tool Restoration & Tools 10
nevets ball joint rubber boots Austin Healey 2
1 E type upper ball joint rebuild... anyone done one Jaguar 1
Cain Lubing Outer Tie-Rod Joint/Upper Ball Joint Triumph 5
D TR4/4A TR4 inner ball joints Triumph 8
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
Joe Reed General MG MG logo ball point pens... MG 0
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
S TR2/3/3A this shifter/ ball and cup Triumph 5
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
T sourcing linkage ball/sockets Austin Healey 13
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
Mark_Barton Ball bearing in Float Chamber? Triumph 8
