Lubing Outer Tie-Rod Joint/Upper Ball Joint
Cain
Hello all. I thought a couple of more questions on the front suspension rebuild.
I'm adding new outer tie-rod joints. Do I just fill the rubber boot with grease?
I'm re-using the upper ball joints, but I'm installing new rubber boots on them. Should I fill the bottom of the boot with grease or just put grease in the joint through the zerk?
Thanks,
Rick O.
The tie rod ends come lubed from the factory; no need to grease the boots. Ball joints should be lubed their Zerks.
Cain
Cain
I was wondering if the tie rod ends were lubed, because these wouldn't budge when I took them out of the box and tried to move them by hand. They came with a plastic brace on the exterior to hold them at a 90 degree angle in the box. I took the brace off and couldn't move the joint.
Mark Jones
Gee, you got me thinkning Cain; I just installed new tie rod ends on my Spitfire and they were extremely stiff as well.
I've heard of people filling a syring with grease; poking the needle through the rubber boot and greasing them that way. Gives new meaning to shooting up. I have also heard of people drilling a hole through the top of a sealed tie rod end and installing a zerk; you'd have to very careful to keep metal filings out though.
Alan_Myers
Hi Cain,
I just saw your post and hope you've got the job done, but, if not, here's a little info. Most tie rod end replacements now offered are the sealed type, pre-greased at the factory and no attention needed or possible (although it's possible to use a syringe, as suggested, to add grease, or some have modified to add a grease zerk but that's tricky, keeping metal chips from the drilling and tapping out of the ball). The thought on this is just to replace them when worn, rather than try to lube them regularly. It's still possible to find the ends with zerks that require grease, but I don't know of a reliable source for LBCs.
As to the top ball joint, why aren't you replacing it? It takes a pretty good beating and chances are if the tie rod ends need replacement, so too does the upper ball joint. I try to replace all wear & tear parts at the same time, since I don't enjoy taking the front suspension apart any more often than necessary. If you do just replace the boot, it's your call whether to pack the boot with some grease or just fill it once it's installed. The latter method will probably make reassembly less messy. If you do reuse the upper ball joint, while it's apart it might be a good idea to push some fresh grease through the ball to purge any dirt that's found a way in and get all the old grease out. Good luck with the project!
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
S TR2/3/3A Lubing the water pump on a tr3 Triumph 1
T lubing trans input shaft splines; torquing pressur Spridgets 2
G Lubing a hidden Alemite Triumph 6
M Lubing Tach and Speedo Cables Triumph 3
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
B TR4/4A Outer tie rods Triumph 8
69MGC MGC Replacing an Outer Wheel Well panel MG 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
red57 What is correct wire harness outer wrap Austin Healey 17
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
Lukens Outer rocker showing "rust" Restoration & Tools 11
D TR2/3/3A 7.68, outer tie rod Triumph 4
B Outer steering column connection to the steering box Austin Healey 6
H General Tech Door Glass outer seals installation Triumph 6
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
F TR4/4A TR4 inner and outer sills Triumph 2
MisterB Outer structure repair order/checklist Austin Healey 9
S TR2/3/3A outer sill and fan tail Triumph 11
red57 Outer Sill/Rocker fit problem Austin Healey 11
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
M BT7 Outer Sill Replacement Austin Healey 2
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
H TR4/4A Outer door waist seal Triumph 5
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
S inner sills, outer sills, a post...where to start? Spridgets 28
I Sealing new outer panels on BN1 Austin Healey 10
O TR6 Outer Rockers WTB Restoration & Tools 0
O TR6 TR6 Outer Rocker Panels WTB Triumph 0
G OD of inner spring is tight to ID of outer spring Triumph 3
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
G excess wear on outer edge of front tires Austin Healey 13
M Photos of my outer sill repair Spridgets 11
M TR2/3/3A TR3 outer sill replacement Triumph 15
Jim_Gruber Looking for DS Outer Rocker - Front 4" Spridgets 9
hondo402000 TR6 TR6 outer sill replacement Triumph 2
germanmichel Fixing outer tube in steering box Austin Healey 11
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
J TR6 joining the inner and outer sills on a TR6? Triumph 1
G TR2/3/3A TR3 lower outer trunnion Triumph 4
M Outer Wheel Bearing - interference fit v Quality? Triumph 2
J TR6 Replacing TR6 Outer Rocker Panels Help Triumph 1
G Plan 9 from Outer Space Triumph 3
