TR6 TR6 carb "ball joints"
mrv8q
So I'm cleaning up my carb linkage, after installing my cleaned-up intake/exhaust manifolds, water pump housing, etc., and I come across these sad linkage balls.
I checked the TR6 parts catalog, and I am surprised there's no separate number for these things. The book, and Moss catalog (don't) show them as a control arm likage assembly. Anyone know if these are available elsewhere? There are 3 in total; two as in the picture, and one has a wider thread and nut...
DNK
Re: TR6 carb "ball joints"
Kevin has a 3. Which parts? Somebody might have some used ones
dklawson
If the OEM parts aren't available from the sources referenced above, be sure to measure what you have left and visit https://www.mcmaster.com. In the FIND field enter "1132" which will take you to catalog page 1132. At the bottom of the page that opens up you'll find miniature, separable rod ends.
McMaster sells to anyone with a credit card, their shipping charges are reasonable... and shipping is VERY fast.
TR3driver
Great Pumpkin - R.I.P
Item 88 and item 83 in the Moss diagram both have ball ends like that.
But I wouldn't bother looking for used ones, as they are pretty much all rather worn after all these years. Seems that no one ever puts a drop of oil on them, since the handbook just lumps them under "several small control joints".
As my parts guy used to say, "You've already got a used one."
Many, many years ago, before I knew of either Moss or TRF, I walked into a big truck (semi) dealer and bought some of those ends off the shelf. Our 58 White bus used exactly the same things, including the threads (which ISTR are British rather than SAE). Only it's throttle linkage was probably 25' long as it was a 'pusher' with the engine behind the rear axle.
DNK
Ok UNCLE, I've seen this many times and I GIVE UP. What is ISTR
TR4nut
AFAIK, ISTR is 'I seem to remember (or recall)' /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Randy
mrv8q
mrv8q
So I thought I'd update this topic from last year, and how I acquired "ball studs".
Ordering the 148496 short link rod from TRF supplies 2 of the ball studs:
There are 3 ball studs needed, though, and one of them that comes with the short link rod has a longer depth of the stud, which might eventually interfere with the carb heat shield I might use...
I'll call or email TRF, and see what they say....
Crankshaft
I found this by following a current thread. It seems to me that, for those of us on this British forum, BYU should be added to the list that Randall referenced. (Bob's your uncle)
T TR6 TR6 Carb Gasket Sealing Triumph 1
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
R TR6 Trouble with TR6, carb now??? Triumph 6
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
T TR6 leaking carb TR6 Triumph 17
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
M TR6 TR6 Gas Leak From Front Carb Triumph 5
A TR6 carb problem 73 tr6 Triumph 10
W TR6 Carb plug TR6 Triumph 2
W TR6 carb question tr6 Triumph 1
R TR6 Tr6 Carb alway lean Triumph 24
T TR6 Rookie photo od TR6 carb cleaning Triumph 2
I TR6 Carb help please for 69 TR6 Triumph 14
I TR6 TR6 carb adjustment teacher needed Triumph 30
ScottTR6 TR6 74 TR6 Carb Triumph 5
TR6oldtimer TR6 What's wrong with this carb '73 TR6 Triumph 7
TR6oldtimer TR6 TR6 Carb Diaphragm Triumph 5
T TR6 TR6 carb rebuilds? Triumph 18
I TR6 69 TR6 carb questions Triumph 2
I TR6 69 TR6 more carb adjustment questions Triumph 7
mrv8q TR6 TR6 Carb measurement Triumph 3
N TR6 TR6 Carb Float Adjustments Triumph 3
I TR6 69 TR6 carb tuning help Triumph 8
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
N TR6 TR6 Carb spacers/Insulators Triumph 4
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
B TR6 TR6 carb tuning vs. HP Triumph 12
I TR6 Carb rebuilding/assessment 69 TR6 Triumph 6
I TR6 Source for good carb rebuid kit for TR6? Triumph 2
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
G TR6 Question for TR6 triple carb owners Triumph 21
AltaKnight TR6 TR6 carb euphoria! Triumph 3
I TR6 TR6 carb help Triumph 4
T TR6 Recommendation on '71 TR6 Carb Rebuild Kit? Triumph 7
SpannerMan TR6 TR6 Crankcase breather/carb replacement questions. Triumph 9
RomanH TR6 TR6 Zenith Carb Problem Triumph 5
AltaKnight TR6 TR6 ZS carb rebuild Triumph 4
Webb Sledge TR6 TR6 Carb to Lucas Injection Conversion Triumph 4
jerrybny TR6 73 TR6 ZS 175 CD-2 carb question Triumph 6
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
