TR2/3/3A overdrive transmission, cosmetically clean
sp53
Well when they said a tr3 is the poor man’s real sports car, they had me in mind. I purchased the overdrive transmission that was in the 61 tr3 which was in the garage fire. The switch going to the dash still clicks but the insulation around the wires is burned off. The electrical stuff on top off the shifter looks ok and the solenoid on the side looks good with the rubber boot on top looking like it survived. The trans outer case needs a good cleaning. I think I will do that first and then install it and see how it works or perhaps do a total rebuild this winter. Anyways in the past with a non-overdrive I would pressure the outer case and then pull the cover tip it over drain out the fluid and put new fluid in-- drive it a little and change the fluid again, but with the OD I am not sure what to do. I do not want to trap water in there somehow, so I am looking for suggestion on how to cosmetically clean the case while the trans is still together.
CJD
Great! Now we'll be rebuilding overdrives at the same time!
I usually pressure wash too, after taping over any vents or seals. My second choice is carb cleaner for smaller parts, and kerosene for big parts. It's nasty no matter what.
The only thing I might do different, is I don't change the fluid on old trannies, unless I know for sure it has been changed regularly. A lot of metal chips and filings from synchros and gear grinding settle to the sludge in the bottom and become harmlessly trapped there. If you change the fluid, all those chips free-up at one time and make a mess of the bearings. I have changed fluid 3 times on old cars that I bought with manual gearboxes...and all 3 times the trannies started howling shortly after. On one the countershaft broke within a week.
TR3driver
Great Pumpkin - R.I.P
Problem is, an overdrive has a pressure lubrication system. It doesn't just run on splash like most manual transmissions do, but sucks oil up from the lowest point.
So at an absolute minimum, I would plan on pulling the OD drain plug, to clean the screen and magnets. (If somehow you got an early model without the magnets, I'd add at least one magnet.)
Taping over the vent is a good idea, too. but I wouldn't even consider leaving the old oil in there, even if it hadn't been through a fire. Personally, I would also want to do a bench pressure test, as running with the pressure too low or too high can further damage the unit; but that's just me.
S
sp53
Well I will have to do a yahoo search or have you explain what you mean by a bench test Randall. My experience with overdrives is very limited, but I always wanted one and it makes doing this project more fun and more interesting. I also purchased the wire wheels off the car and that will be new to me also. The wheels look ok, but I am judging with limited experience. The tires were new Michelin XZX made in France. The spare is still nice and one other tire looks to be usable. All the tires were new, but the heat cracked the side walls on the other 3, so I will be asking wirer wheels questions soon, I hope.
CJD
And I just got a set of wires off EBay on the way...so Steve, you sure you're not watching what I'm doing?
Geo Hahn
Apart from avoiding damaged I'd want a bench test just to be reasonably sure it worked before installing. I've wrassled with that OD box some and it is not an exercise I would want to repeat multiple times just to get the unit sorted out.
...The tires were new Michelin XZX made in France...
The thing to look at there is the date code -- most tire sites explain where to find it & how to decode it. I haven't seen 165/15 XZXs for sale in the US since the earlier part of this century, though perhaps someone has a more recent source.
TR3driver
Here's a good article that outlines the process. https://www.buckeyetriumphs.org/technical/AOD/AOD4/AOD4.htm
Basically the idea is to find a way to spin the OD before installing it in the car, with a pressure gauge attached, so you can operate the solenoid and watch what the pressure does. I used a 1/2" drill motor, plus a short length of radiator hose that would just fit over the input shaft and the nose of the drill chuck (with clamps on both ends).
You don't have to literally do it on a bench, but I find that a lot easier than stooping over to do it on the floor.
PS, here's a good article on how to find the age of your tires. Assuming they bear the US required markings that is. If they are gray market imports, they might not have the codes.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11
Geo Hahn
I salvaged a motor from an old Maytag washer to use for spinning a gearbox -- though I have never used it to test an overdrive.
It is a bit of fun though.
Tinkerman
I used arubber hose clamped to the shafts of my 1/2 inch drill motor and the tranny shaft to run mine up. Set it up on the same type of rig as is in the picture. Worked out just fine.
I WOULD NOT USE KEROSENE to clean the exterior. Kerosene leaves an oily residue on the parts. I have always used mineral spirits or paint thinner for parts cleaning. I have paint thinner in my parts cleaner and it works just fine. Dries quickly also. Just my thoughts and experience.
Cheers and good luck, Tinkeerman
CJD
My old man favored diesel for cleaning. It left a film that took weeks to dry. I switched to kerosene because it doesn't leave a residue. In fact, kerosene is what I have been using in my parts cleaner for decades.
S
sp53
Well it sounds like the Jungian collective consciousness with respect to the tr3 John. In fact from my perspective, I cannot understand way more people are not involved. It beats TV. You guys are killing me with this overdrive stuff. I thought Geo was going to say it is the most fun he has had since he took apart the washing machine.
TR3driver
I'm pretty sure that Geo's position echoes my own : R&Ring the gearbox (especially with OD) is a big enough pain in the anatomy that it is worth spending some "quality time" to avoid having to do it again. It certainly is not something I do for fun!
Fun is getting to the top of the entrance ramp, and instead of letting off the throttle to shift, keep it mashed to the floor and flip the OD switch. As it says in https://drive.google.com/file/d/0B2...NjM3LTlhNGQtNDZjMmNkZDdiMzBh/edit?usp=sharing, Real Good !
dave m
regarding the tyres 165/15 xzx for sale
-longstone tyres in uk sells them quite reasonably and they are delivered to your door
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
J Transmission and Overdrive Rebuild Austin Healey 6
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
KVH TR4/4A Transmission and Overdrive Capacity Triumph 6
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
Marvin Gruber General TR Overdrive transmission serial number Triumph 1
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
L Transmission BN2 with 28/1292 overdrive Austin Healey 3
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
W TR2/3/3A Looking Into Overdrive Transmission Triumph 16
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
AUSMHLY Flushing the transmission and overdrive Austin Healey 6
drooartz Servicing transmission and overdrive MG 9
J Overdrive transmission question Triumph 4
KVH TR4/4A TR4A Transmission Overdrive Plug Leak Triumph 13
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
John_Mc MG overdrive transmission on CL MG 2
N Seating The Ball On An Overdrive Transmission MG 10
5 Water in overdrive and transmission Austin Healey 4
Johnny Removing Overdrive from transmission. Austin Healey 1
V a type overdrive transmission Triumph 8
C Transmission conversion for overdrive what to do? Austin Healey 15
Mickey Richaud Transmission/Overdrive Wiring MG 3
6 Overdrive Transmission MG 16
7 Overdrive Transmission MG 1
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
