Overdrive speedo cable question
bnw
I just got the new gray speedo cable from TRF (great sale going on for tr3). Looking at my car, the cable will have to take a very tight 90 degree turn to stay under the tunnel and make it up front. I didn't get a 90 degree fitting with my car so, what gives? Just make the bend and go for it?
TR3driver
Great Pumpkin - R.I.P
It should NOT be making a sharp bend at all. The cable comes out through the slot in the side of the tunnel, then through the floor behind the hand brake lever. Wide gradual turn out against the RH frame rail, then up the firewall on the RH side and across in front of the battery.
That's why the OD speedo cable is so much longer than the non-OD.
B
bnw
So in, out, then back in again. Anything special about the out, in locations as is rubber gaskets/plugs?
TR3driver
Nope, just the handbrake boot that covers all of it. Since I've got a 4-synchro box in my TR3, which is just a bit longer than the original 3-synchro, I added a split piece of rubber tubing where the cable goes through the floor, so it wouldn't rub on the edge of the opening. But you probably don't need even that with a stock gearbox.
If memory serves, there is a clip that holds the cable to the RH frame rail, then another one on the ledge in front of the battery box. Otherwise it just lays loose.
Oh yeah, there is a grommet where the cable enters the cabin over by the pedal box. A real PITA to install over the nut on the speedo end. Soaking the grommet in silicone spray seems to help, a little.
mallard
Randall is there any way to get a drawing, or diagram of that? One of the many things that were not on the car when I got it.
TR3driver
Of what, Keith? Here's all I can find at the moment, which shows the cable crossing in front of the battery
PS, this was taken after the car was wrecked, which is why lots of things appear to be partially disassembled. Later they were completely disassembled
mallard
The cable was removed from my car when I got it. I have no idea of the correct routing. Any pictures you have would help. I will save them for future reference.
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
M Speedo pinion on Overdrive Austin Healey 1
Q TR2/3/3A Speedo Gear Drive On Tr3 Overdrive? Triumph 0
Y Speedo/overdrive curiosity Austin Healey 14
Airfix TR6 TR6 overdrive speedo pinion Triumph 2
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
