oxford
Hi everyone
I've checked the archives for this, but can't find the definitive answer.
My car is a BN4, not on the road yet but 3/4 through restoration. Anyway, I noticed today while fiddling with stuff to try and get the engine running since rebuild, that the overdrive solenoid seems to be switching on regardless of the position of the dash switch.
The inhibitor switch is working, but when I move the gear lever towards 4th gear the solenoid activates, even if the dash switch is in the Normal position.
I've checked the dash switch and it seems fine. The relay and throttle switch are original, but in good condition and the loom is new. Could this be something to do with the throttle switch adjustment?
Any ideas gratefully received.
Thanks
Matthew
Thanks
Matthew
