Overdrive Escutcheon Question: Reversed?
62BT7
I have a '62 BT-7 with overdrive. I'm well into replacing the dash and dash pad, and was planning to replace the old overdrive escutcheon dash plate for the original switch (which works perfectly fine) with a new one. I bought it some time ago and cannot figure out where, I assume Moss or Victoria B. Looks really cool, shiny...but I just realized it's the wrong one.
The original is slightly smaller in diameter (.50 cent sized) than the replacement, and has a straight/vertical section on the right side, sort of like a closed off letter "c." Here's the odd thing, on mine the word "Normal" is on top, "Overdrive" on the bottom. The new one I have has these words reversed, is slightly larger, and has a little prong at the 6 o'clock position of the opening. Looks like the one offered in the Moss catalog but it won't fit at all.
Does anyone know if my original escutcheon (and switch, I suppose) is off a Healey? Any ideas where to get a similar escutcheon without replacing the whole switch (and I assume reversing the wires?) For what it's worth my original temp/pressure gauge was in celsius, not F. Any ideas are most welcome, thanks.
-Tom Pierce
Keoke
Hi Tom, The "Closed off letter "C" you mentioned, is in fact a standard "D" hole for keying and mounting the switches.
What appears to be "odd" is typical of the Healeys the switches usually go up to the off or normal position.
Potential problem solution ; put new switch in the bin and order the right one in.--Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
