TR2/3/3A overdrive solenoid
TFB
Od stopped working so I pulled of the cover to check what I thought would be loose linkage.
The solenoid engages,nothing loose from original setup that worked perfect for the last 12k miles .The solenoid is not giving the required travel.
I can push the plunger up just a little with my finger when engaged which looks like the extra travel I need.Is this normal or do I need new solenoid?
Thanks
Tom
Sarastro
It should move all the way to a hard stop at the top.
Sounds like it has some crud in it, or the internal switch is stuck, or something is binding in the lever/operating valve components, or the lever came loose and it is out of adjustment. I would remove the solenoid, check it, and if it's OK, see if the operating lever assembly works smoothly. Then, put it back together and adjust the operating valve for standard 30 mils of movement. Can't be much else.
http://www.tonydrews.com/Overdrive/A-type OD manual.pdf
http://tr4a.nonlintec.com/transmission/#resources
T
TFB
Thanks for the reply Steve.
I looked at everything again and the solenoid was going to full stop at top but I mistook the lever play for the plunger.
Started from scratch and adjusted to just engage and disengage which put the lever a few degrees from where I marked it before loosening.
Maybe just compensating for od clutch wear? I dont know if this is commom after 12-13k mi but it seems to be normal again.
Tomorrow the cover goes back on a hopefully a good test drive.
Thanks
Tom
A TR4/4A TR4 Overdrive Solenoid Triumph 19
R TR2/3/3A Overdrive Solenoid Triumph 6
B Overdrive solenoid Austin Healey 12
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
nevets Access to overdrive solenoid and switch Austin Healey 5
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
S Overdrive solenoid problem on a BJ8 Austin Healey 3
S TR4/4A overdrive solenoid rubber boot Triumph 8
M AHBJ8 '67 overdrive solenoid Austin Healey 8
2wrench New Solenoid Installed on J Overdrive and now no juice to the Solenoid. Triumph 3
H overdrive solenoid question Austin Healey 4
bighealeysource Help -think I've got a bad overdrive solenoid ? Austin Healey 8
bighealeysource Overdrive solenoid on BN6 Austin Healey 2
thechileman TR4/4A Overdrive Solenoid issue TR4 Triumph 8
B What's the BUZZ from the overdrive solenoid Austin Healey 3
6 overdrive solenoid Triumph 5
Ed_K Overdrive solenoid rubber piece on a BJ8 ? Austin Healey 2
J Overdrive solenoid--How do I diagnose weakness? Austin Healey 8
kch Overdrive solenoid - fuse question Austin Healey 8
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
