overdrive solenoid question
hubosity
I putting in a new overdrive solenoid and I have some basic questions:
1. should I lubricate the piston and sleeve before putting them together or leave them dry?
2. all of the diagrams show a rubber seal or bellows looking part around the piston just above where it mounts to the lever. It seems to cover the exposed portion of the piston. This rubber part did not come with the solenoid and seems to show N/A on the Moss catalog. The old one is long gone. do i need it?
thanks in advance!!!
Rich
Keith_M
I did not lubricate mine, and it works fine. I doubt that a small amount of graphite or other similar lubricant would hurt though.
I think you'll want to get that rubber boot. It serves to keep water and dirt from getting between the piston and the sleeve. I don't know if Moss has them, but I got one recently from Healey Surgeons.
Keith
Richard Dickinson
You will definitely want to get that rubber boot. The first problem I had after I bought my BT7 new was apparently the boot was left off at the factory. The solenoid seized up.
H
hubosity
thanks guys, I'll definitely pick one up while I've got the tunnel off.
I found out that my dash switch was bad in addition to the solenoid. Can't wait to get the overdrive working again!
5
57_BN4
If the rubber buffer that sits below the solenoid plunger is missing then replace that too as the solenoid travel is set by it.
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
kch Overdrive solenoid - fuse question Austin Healey 8
A TR4/4A TR4 Overdrive Solenoid Triumph 19
T TR2/3/3A overdrive solenoid Triumph 3
R TR2/3/3A Overdrive Solenoid Triumph 6
B Overdrive solenoid Austin Healey 12
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
nevets Access to overdrive solenoid and switch Austin Healey 5
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
S Overdrive solenoid problem on a BJ8 Austin Healey 3
S TR4/4A overdrive solenoid rubber boot Triumph 8
M AHBJ8 '67 overdrive solenoid Austin Healey 8
2wrench New Solenoid Installed on J Overdrive and now no juice to the Solenoid. Triumph 3
bighealeysource Help -think I've got a bad overdrive solenoid ? Austin Healey 8
bighealeysource Overdrive solenoid on BN6 Austin Healey 2
thechileman TR4/4A Overdrive Solenoid issue TR4 Triumph 8
B What's the BUZZ from the overdrive solenoid Austin Healey 3
6 overdrive solenoid Triumph 5
Ed_K Overdrive solenoid rubber piece on a BJ8 ? Austin Healey 2
J Overdrive solenoid--How do I diagnose weakness? Austin Healey 8
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
