Overdrive solenoid rubber piece on a BJ8 ?
Ed_K
I have finally got around to working on my overdrive.
I have a new solenoid from Moss that I am going to install and it has a rubber bellow piece around the operating rod. My car didn't have one when I took it apart. The base of the rubber piece appears to be too thick to use on my BJ8. Is this piece supposed to be used on a BJ8 ?
Also, what are you supposed to use as a seal in the grove of the transmission tunnel cover ? I originally used used RTV and will not be using that again for this application.
Thanks,
Ed
/bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
Keoke
Hi EdK, yes there is a dust shield on the plunger. I have never found a use for it on the BJ8. There were and stil may be available from some sources a set of rubber seals that fit over the tunnel flanges mounted to the floor, I simply made mine out of neoprene rubber strip material ---Keoke
Ed_K
Ed_K
/bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Ed
S TR4/4A overdrive solenoid rubber boot Triumph 8
A TR4/4A TR4 Overdrive Solenoid Triumph 19
T TR2/3/3A overdrive solenoid Triumph 3
R TR2/3/3A Overdrive Solenoid Triumph 6
B Overdrive solenoid Austin Healey 12
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
nevets Access to overdrive solenoid and switch Austin Healey 5
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
S Overdrive solenoid problem on a BJ8 Austin Healey 3
M AHBJ8 '67 overdrive solenoid Austin Healey 8
2wrench New Solenoid Installed on J Overdrive and now no juice to the Solenoid. Triumph 3
H overdrive solenoid question Austin Healey 4
bighealeysource Help -think I've got a bad overdrive solenoid ? Austin Healey 8
bighealeysource Overdrive solenoid on BN6 Austin Healey 2
thechileman TR4/4A Overdrive Solenoid issue TR4 Triumph 8
B What's the BUZZ from the overdrive solenoid Austin Healey 3
6 overdrive solenoid Triumph 5
J Overdrive solenoid--How do I diagnose weakness? Austin Healey 8
kch Overdrive solenoid - fuse question Austin Healey 8
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
