Overdrive Question
stretchit2
Fellas (& Ladies of course)
Over the years I have replaced virtually evey component of my Overdrive system: Switches, Relays, Solenoid, you name. For about the past year it has been working flawlessly. Last Saturday I was out on a drive and I noticed that the when I switched it to off (and gave it the requisite pop of the throttle) the overdrive did not disengage. Hah, so I pulled over shut the car off restarted her and headed off. 1,2,3,4 hit the overdrive switch it works perfectly, then I turn the switch off, pop the throttle.....nothing. Several more attempts same result (yes, I may be insane). Does anyone have an opinion as to which component may have failed. BTW, when I am in neutral and I move the gear shift lever back and forth I hear the solenoid. I'm guessing switch, mostly because it is the easiset part to repair.
What say you?
Jeff
Most suspect to me, would be the throttle position switch. For an easy test, put both (2) of the wires under one (1) terminal, and go for a drive to test the function.
The TPS would be my guess too. The TPS is a set of points and, like any points, they can stick. Check as Randy suggested, then check the setting and, if necessary, you can carefully open it up and file--and clean--the points.
Stretch
I had a problem that caused the overdrive mechanism to hang up in the on position. I had to reach under and pull down the lever on the right side of the tranny. See if this lever can be pulled down once the solenoid is de-energized. Turns out the rubber bump stop below the solenoid plunger in the box on the left side of the tranny had hardened and crumbled. Seems unlikey but all I could figure is that the additional travel allowed the plunger to pull up harder to the point it jammed in the full up position. Since fixing I have had no trouble.
Keith_M
The arm on the throttle position switch clamps on to the shaft that goes through the switch. If the bolt holding that clamp has loosened over time, depressing the throttle will not move the shaft and the switch won't work. Easy to check though: just operate the throttle linkage at the carbs and make sure that the shaft is turning. If it is turning, it's not too difficult to check its operation if you have an ohm meter. I can't at the moment remember if it's supposed to be continuous when the pedal is up or when the pedal is down.
John Turney
If it's not the TPS, on mine the overdrive cone clutch was worn and the sliding element would go to far and get stuck. But I agree with the TPS since it disengages when you turn it off. I had to use reverse to disengage.
D TR2/3/3A Overdrive question. Triumph 49
KVH General TR Overdrive Up-date and Clutch Question Triumph 2
K Overdrive Screen Replacement Order Question Austin Healey 4
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
D TR2/3/3A TR3A overdrive question Triumph 6
I Overdrive question..? Austin Healey 8
D TR2/3/3A how to question for overdrive Triumph 29
C BN1 Overdrive drain plug question Austin Healey 0
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
K Overdrive pressure question Austin Healey 4
S TR4/4A overdrive question Triumph 1
oxford overdrive question Austin Healey 5
B Overdrive Oil Pump Installation Question Austin Healey 10
TR3TR6 TR6 Question about a TR6 J overdrive Triumph 12
A TR5/TR250 Overdrive question Triumph 12
M Exhaust fiasco & overdrive question Austin Healey 7
bighealeysource Overdrive question on BN2 Austin Healey 3
nevets Overdrive electrical diagnostics question Austin Healey 5
D A type overdrive question. Triumph 3
H overdrive solenoid question Austin Healey 4
J Overdrive Question Triumph 9
bighealeysource Overdrive fusing question on BN6 Austin Healey 10
J Overdrive transmission question Triumph 4
S Spitfire 76 spitfire overdrive test question Triumph 5
Coyote1 Overdrive wiring question Triumph 8
B Overdrive speedo cable question Triumph 6
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
G How sweet if was AND overdrive question Triumph 22
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
TR3TR6 J-type overdrive question Triumph 5
PAUL161 72 Overdrive rear oil seal question. MG 0
71tr J-type Overdrive Pressure Port Question Triumph 2
Monark192 MGB-GT 67 BGT - Overdrive Trouble Shooting Question MG 0
Monark192 MGB-GT 67 GT Overdrive trans oil change question. MG 6
7 question after testing a J type overdrive Triumph 5
roofman Spitfire 1975 Spitfire overdrive question Triumph 6
T MGA MGA overdrive - that is the question MG 23
T Overdrive question - electrical Triumph 14
N And Another Overdrive Question MG 6
T TR2/3/3A TR3 overdrive question Triumph 5
6 Overdrive Escutcheon Question: Reversed? Austin Healey 1
curtis 100 overdrive question Austin Healey 5
Bob McElwee Overdrive Operating Valve Question Austin Healey 6
TR_Jim GT6 GT6 overdrive question Triumph 3
S Overdrive Question Austin Healey 2
