100 overdrive question
curtis
I have had an oil leak from the gearbox for sometime in my BN2 (four speed).I decided to look at it and guess that there must be a problem with the first motion shaft seal which would then manifest itself with drips through the bottom of the front gearbox casing?
However there is also a leak from the overdrive where the setting lever goes into the casing. That's the lever on the shaft with the solenoid lever on the other end.
My question is. How easy is it to replace this little seal?
Can you remove the setting lever and then access the seal. Hooking it out?
Can you slide the valve opening shaft across leaving the seal free to be extracted? If you do pull it across a little will it go back into position afterwards?
Thanks in advance.
curtis
curtis
Just following on from the above. Bearing in mind the positioning of the little seal would it be possible for a lot of oil to escape via this route? In other words from full to off the bottom of the dipstick. Is that part of the overdrive pressurized?
Stretch
The lever is held in place with a roll pin. Punch it out and wiggle the lever off. The seal is an o ring. Easy to pick out and replace once the lever is off. I replaced mine with the tranny out. Don't know about being able to punch out the pin with the O drive in the chassis. No oil pressure behind it; the lever hold it in place.
curtis
curtis
Thanks for that Stretch.
Any thoughts about the amount of oil that could escape via this seal. Once the level had dropped a bit would it still come out?
Keoke
Hi Curtis, Stretch gave you some good advice I never gave it much thought before. If the seal is leaking it will continue to leak until the head of oil in the case rests below the shaft. The leak rate will continuously decrease as the head recedes.---Fwiw--Keoke
W Healey 100 Overdrive stopped working Austin Healey 15
C 1959 100-6 Overdrive installation Austin Healey 4
C Installing overdrive on 1959 100-6 BN6 Austin Healey 3
HEALEYJAG 100 BN-1 Overdrive malfunction Austin Healey 14
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 6
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 8
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
