Re: wheres the efi relay located
the red diode box makes a clicking noise when trying to start it,is it bad.i've also tested the injectors,there getting power,i'm getting fuel,fuel pump relay is new,new ignition switch,good fuel pump,good spark.i have 3 ground wires and 1 positive wire on the coil.is there suppose to be 2 positive wire's.i feel it's real close to starting.checked all ground's cleaned plug's and connectors.
