Glen_B
I'm entering the final phase of the project at last. Both spark and fuel are now totally under control of the Megasquirt computer. Fine tuning of the boosted areas of the fuel and spark maps is all that remains. Dropping advance to 12deg at 10lbs of boost was too much and the engine would sag every time I pressed it. Now, with advance set to 22deg at 10 lbs of boost, things are getting pretty good.
Cold start is dialled in. Three cranks of the motor and it starts and idles. I can pull out of the driveway after a few seconds. I log each run and use a program to analyze the log when I get home, and then re-tweak the fuel and spark tables based on the analysis.
The engine runs great, the plugs look perfect and the mileage is excellent. Once the boost areas of the tables are done......LOOK OUT!!! The car already drives better than it ever has and the power, up to the boost phase, is excellent.
At this point in time, a word for the armchair experts about "Charge Robbing", "Siamese Porting", and "Turbo-lag",
talk is cheap but results come from work and first-hand experience. All of the above are very minor nits unworthy of being picked. /bcforum/images/%%GRAEMLIN_URL%%/thirsty.gif
Glen Byrns
Glen Byrns
