EFI bugeye HP numbers
Glen_B
Since the dyno appointment, I've calibrated the Megasquirt to match up to the dyno numbers. After logging several runs out on a level road with foot-to-the-floor passes in all gears, I analyzed the data for each gear individually and found that bugsy is generating 110HP at the wheels in 2nd, 3rd and 4th at about 4500rpm and 10lbs of boost. For a minute there I thought I was getting 130HP at the wheels, but putting the CORRECT car/driver weight, rear-end and gear ratios and smoothing the curve brought me back to earth.
That said, I'm done messing with the fuel and timing tables and on to hooking up the last bells and whistles that are on the circuit board. This weekend I got the computer to take over the electric radiator fan. Works great, set the "on" point at any temp you want, set the hysteresis, and Bob's your uncle. The only remaining problem is the tachometer. With the spark circuit in the Megasquirt, you can't drive the elec. tach from the coil neg. side as usual. I added a tach driver circuit as recommended, but so far, still no tach movement. Hardly a deal breaker since I can tell the RPM by ear pretty much, but I'm not done fussing with it yet. Total victory will be mine!!!
Glen Byrns
drooartz
Now that's one fast Bugeye. Very cool.
And +1 on the videos. :smile:
jlaird
Glen_B Bugeye EFI progress Spridgets 10
Glen_B Megasquirt EFI on bugeye Spridgets 11
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
F TR6 Patton EFI Triumph 1
I TR6 TR6 EFI Conversion Triumph 19
HealeyPassion AH EFI build... again Austin Healey 41
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Tremelune EFI, engine swaps, reliability... Spridgets 12
RAC68 Wedge TR7 - Anyone Convert from Carbs to EFI Triumph 6
Glen_B EFI Megasquirt help available Spridgets 37
Morris EFI for you Doug Spridgets 5
L Turbocharged, efi MG MIDGET. VROOM, whoosh, psssss Spridgets 19
S Wedge TR8 non EFI, Air Filters Triumph 2
S Wedge 1980 TR8 a/c non efi Triumph 19
HealeyPassion EFI Healey project Latest Austin Healey 14
T Mega-Squirt EFI [for A series engines?] Spridgets 6
HealeyPassion EFI Healey project Latest Austin Healey 3
Bret Bret's EFI Skunk Works hits a few speed bumps. MG 9
Glen_B Here are some efi pics Spridgets 14
Glen_B EFI is FINISHED!! Spridgets 10
Glen_B Turbo EFI progress Spridgets 14
Bret Up-date on Bret's MG Skunk Works EFI project MG 7
Morris Midget EFI: Opinions wanted Spridgets 15
Glen_B EFI progress Spridgets 5
G Evante EFI Conversion Other British Cars 0
Morris Midget EFI pics Spridgets 8
Morris Midget EFI fuel pressure problem Spridgets 10
M 4CU EFI Module 3.5L Rover V8 1985 Marcos Mantula Rover / Land Rover 9
Bret Bret's EFI & O/D transmission MG 7
Bret Woo Hooo! Up-date on my EFI kit installation! MG 5
Bret Moss EFI kit and O/D tranny Latest thus far... MG 8
healeynut Healey EFI ... q's??? Austin Healey 7
R ALANA -- How's that EFI going? Triumph 14
Atrus Megasquirt EFI Question Spridgets 7
Morris Spridget EFI survey Spridgets 11
LastDeadLast Pinging Alana, EFI related Triumph 1
Morris AH Spares EFI Spridgets 3
A TR6 TR6 EFI - where do I start? Triumph 26
8 efi relay Jaguar 4
Bret Speaking of the Moss EFI kit MG 2
B Spitfire common EFI swaps for 1500 Spits? Triumph 5
Bret Moss EFI kit & other good news! MG 14
Bret MGB Moss Motors EFI for the MGB! MG 3
StagByTriumph Wedge TR7 EFI system on Ebay Triumph 7
Bret MGB MOSS's EFI kit for ZS MGBs MG 2
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
