Bret's EFI & O/D transmission
Bret
EFI under the bonnet!
Starts hot or cold on the first turn of the key.
OD transmission,
Before:
After:
As you can see it's a much more comfortable ride at freeway speeds. /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
tony barnhill
Great Pumpkin - R.I.P
Looking good, Bret!
Guys, I've gotta give kudo's to Moss on this one:
In March 2006, I sold the kit to Bret...when he got around to installing it just now (about 1-1/2 year later), he found a bad EFI unit...he contacted Moss (I wasn't near a phone or computer)...their tech guy talked with his mechanic &, without checking with me to verify the sale (usually they confirm with me that I handled the transaction), he shipped Bret a new part & notified me he had solved the problem.....he didn't even contact my sales guy there at Moss - he just acted to solve Bret's problem....new part shipped on 14th & Bret's driving on 16th!
That's why I like & use Moss!
Stewart
Hows the power compared to the zs carb? I wonder what the fuel economy is going to be like as well. I really need an od tranny.
Nunyas
I'm wondering the same: Is the power delivery as smooth as they make it sound? How does it compare to a single ZS? Do you still have the same tapering off of power as you climb up in RPMs?
I reckon the power delivery would be smoother at the low end, but the curve would be pretty much identical to a single carb on the high end due to the limitations of the intake manifold.
Did you put that manifold on that you'd gotten? The one with the single carb style intake and early style exhaust manifold.
Bret
Bret
Other than the drive home (on the freeway) I really didn't have a lot of time to play with it yesterday because of time constraints. But I'm off today and will go out & do a proper shake down before it gets too hot.
But first impressions where pretty much as advertised. Easy starts (warm or cold) and the throttle response is crisp & instantaneous and steady throughout the entire RPM range. Bumping up the timing a little – the performance is a little better but nothing earth shattering. After adjusting my lifters my mechanic pointed out that my car’s camshaft is quite worn and ready for replacement. Talking about this we think the car would see the most performance gains by using a fast street cam.
Anyway the biggest difference between the EFI & the ZS thus far is the ease of starting and the fact that it is so smooth & steady. Heck even at freeway speeds with my foot all the way down on the throttle the ZS seems to top out, whereas the EFI doesn’t seem to struggle at all & in fact seems to want to keep going beyond the Red Line if I would let it.
That said I did observe a couple of anomalies. At speed it ran flawlessly but after I got off the freeway I noticed a couple situations where I went into second that it seemed to bog down a bit. In both cases I was performing a power-shift – where I maintained pressure on the throttle to keep the RPMs up (~3000 to ~4000) and up shifted (1st to 2nd) & down shifting (3rd to 2nd). However if I was being a little more reserved and actually let completely off the throttle it seemed to work fine.
If I had to guess I’m figuring there’s something in the ECU that monitors engine temp & throttle position that regulates fuel, that I might be confusing. Another thought is that like many modern EFI’s they are very finicky about how hot or cool the air is that is drawn into the throttle body and adjusts the fuel accordingly.
But again this wasn’t noticeable at freeway speeds.
Bret
Bret
One of the coolest things that I’ve got to mention is the O/D transmission. At freeway speeds it’s actually quite pleasant to be cruising down the road at 75-80mph with the flow of traffic and not have to worry about someone in an SUV running over me.
Surprisingly the EFI compliments the O/D tranny quite well. So nice to have the confidence to actually pass slower cars. Flick the switch out of Overdrive and I’m back in Fourth gear turn on the turn signal, check the right lane and press the gas! Whoosh (that fast) – I’m passing on the left like any other vehicle would.
Bret
Bret
Ok, just got back from running a couple of short trips around town I got a pretty good feel for how it performs at street speeds and in stop & go traffic.
All & all I think she seems pretty nice I didn't observe any bogging down when I shift into second but it just dosn't seem like it pulls the same. But I might be imagining things.
That said I'd really like to see how she performs with a fresh camshaft. Other than that I didn't see any problems and I still want to have my mechanic have a look at it because it just seems a little different. But again it might just be in my head.
Nunyas
Bret said:
... Easy starts (warm or cold) and the throttle response is crisp & instantaneous and steady throughout the entire RPM range...
That's nice to know. I've driven stock modern cars where the OEM computers are too slow, IMO. For example, my friend has a Pontiac Sunfire ("sport" model with an auto-trans), and there is a very noticeable delay between pressing the gas pedal and the engine responding, ~especially~ with the car in gear and idling. I ~always~ end up giving it too much right foot because nothing happens when I first push it, and of course by the time the car responds I have so much pedal used I end up laying rubber. Maybe that's an anomaly of mordern automatics, but what ever it is, I hate it.
Bret Bret's EFI Skunk Works hits a few speed bumps. MG 9
Bret Up-date on Bret's MG Skunk Works EFI project MG 7
Bret Bret's Skunk Works Teaser MG 10
Bret Bret's MG Skunk Works Success! MG 10
DrEntropy All Bret's fault! Other Cars 19
Bret It's all in the Details! [more Bret's Shark tales] Other Cars 13
Steve It runs! [Thanks Bret] MG 0
Bret Bret's 78B's Latestd web page. MG 1
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
F TR6 Patton EFI Triumph 1
I TR6 TR6 EFI Conversion Triumph 19
HealeyPassion AH EFI build... again Austin Healey 41
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Tremelune EFI, engine swaps, reliability... Spridgets 12
RAC68 Wedge TR7 - Anyone Convert from Carbs to EFI Triumph 6
Glen_B EFI Megasquirt help available Spridgets 37
Morris EFI for you Doug Spridgets 5
L Turbocharged, efi MG MIDGET. VROOM, whoosh, psssss Spridgets 19
S Wedge TR8 non EFI, Air Filters Triumph 2
S Wedge 1980 TR8 a/c non efi Triumph 19
HealeyPassion EFI Healey project Latest Austin Healey 14
T Mega-Squirt EFI [for A series engines?] Spridgets 6
HealeyPassion EFI Healey project Latest Austin Healey 3
Glen_B EFI bugeye HP numbers Spridgets 4
Glen_B Here are some efi pics Spridgets 14
Glen_B EFI is FINISHED!! Spridgets 10
Glen_B Turbo EFI progress Spridgets 14
Glen_B Bugeye EFI progress Spridgets 10
Morris Midget EFI: Opinions wanted Spridgets 15
Glen_B EFI progress Spridgets 5
Glen_B Megasquirt EFI on bugeye Spridgets 11
G Evante EFI Conversion Other British Cars 0
Morris Midget EFI pics Spridgets 8
Morris Midget EFI fuel pressure problem Spridgets 10
M 4CU EFI Module 3.5L Rover V8 1985 Marcos Mantula Rover / Land Rover 9
Bret Woo Hooo! Up-date on my EFI kit installation! MG 5
Bret Moss EFI kit and O/D tranny Latest thus far... MG 8
healeynut Healey EFI ... q's??? Austin Healey 7
R ALANA -- How's that EFI going? Triumph 14
Atrus Megasquirt EFI Question Spridgets 7
Morris Spridget EFI survey Spridgets 11
LastDeadLast Pinging Alana, EFI related Triumph 1
Morris AH Spares EFI Spridgets 3
A TR6 TR6 EFI - where do I start? Triumph 26
8 efi relay Jaguar 4
Bret Speaking of the Moss EFI kit MG 2
B Spitfire common EFI swaps for 1500 Spits? Triumph 5
Bret Moss EFI kit & other good news! MG 14
