adjustable steering
WALTER
How many dumb questions does a guy get to ask? How do I know if I have adjustable steering and if I do how do I adjust it?
Thanks
Walter
There is a silver (?) spring circling the column just behind the wheel. There is a ring that tightens to hold the setting in place (mine doesn't stay real tight so I can move it in and out even when tight) but the whole thing is not an issue unless you are real short or tall. I'm only 5'10" and I have trouble getting in and out with the wheel any where but all the way to the dash.
Qustions are always good 'cause that's how we all learn and get new ideas about things that had not occured to us. I have better questions than answers so I learn a lot from this forum.
You're close to Tahoe. Come up for the June gathering and check out those things on other's cars. There should be 100 to 200 Healeys here. I beleive there are already 90+ regestered.
WALTER
WALTER
That's great! It was a good thing to find out because they had it all the way out. The car show sounds good. Are you going to the Dixon British Car Show & Swap Meet, May 17.
Thanks
Walter
I've never been. I have to look at my wife's calender. The one with the "Honey Dos" in it. Are you part of the Golden Gate group or the Sacramento group?
WALTER
WALTER
neither, I'm just going. If I went by my honey-do I'd never get to leave the property.
Walter
Check out the web site for the Golden Gate club.
www.GoldenGateHealeys.com
Check out the schedule of events. Last weekend 10 Healeys went up Mt. Hamilton to the Lick Observitory. Up from Livermore down to San Jose. Beautiful Healey type roads. There are rides all around the Northern Cal area. Nice to be out with people who can help when something goes wrong. (One guy's clutch failed at the top.)
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
D BT7 adjustable steering column / steering wheel Austin Healey 1
4tecdog Adjustable Steering how? Austin Healey 8
Lin Loosening adjustable steering wheel Austin Healey 3
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Crankshaft Adjustable steering column? Triumph 11
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
D Adjustable steering wheel stuck Austin Healey 6
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
K Adjustable steering wheel setup Triumph 2
longbridgehealey adjustable steering Austin Healey 6
tahoe healey Adjustable steering tightening Austin Healey 13
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
G Adjustable steering Triumph 4
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
H Adjustable Steering Problem Austin Healey 4
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
P Adjustable Steering Triumph 2
GregW Adjustable steering wheel Austin Healey 13
