TR2/3/3A Adjustable steering wheels
John_Koop
When were the adjustable steering wheels first installed in triumph TR-3s?
How many triumph TR's were fitted with them?
My TR-3A has one and they do not seem to stand up to use as the non-adjustable
steering wheels do.
Can the adjustable type be changed over to non-adjustable type just by replacing
the top portion of
the split steering column that fits the non-adjustable steering wheel?
john
TR3driver
Great Pumpkin - R.I.P
I believe it was a very early option, if not "day one". Listed in the TR2 parts catalogue, and an accessories brochure from August 1954.
No idea how many were fitted, but it doesn't seem to have been terribly popular. Maybe 10% as a very rough guess (based on personal experience with roughly 10 TR3 and only one had an adjustable steering wheel).
The stator tube and control head are also different, although I believe you could use the adjustable version of them with the fixed steering wheel.
PS, Sorry, I don't know if the upper outer column is different or not. I'll be interested in what others have to say, since I may be converting a car to fixed myself.
With a TR3a, you can get by with just hanging the upper inside rod. ( from adj to fixed ). Going the other way the steering tube has the be slotted as well as changing out rod. Early TR2/3 had the one piece steering column so you have to pull whole column and gearbox. If steering wheel is bad I believe it will be easier to just buy aftermarker adj wheel.
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
D BT7 adjustable steering column / steering wheel Austin Healey 1
4tecdog Adjustable Steering how? Austin Healey 8
Lin Loosening adjustable steering wheel Austin Healey 3
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Crankshaft Adjustable steering column? Triumph 11
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
D Adjustable steering wheel stuck Austin Healey 6
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
K Adjustable steering wheel setup Triumph 2
longbridgehealey adjustable steering Austin Healey 6
tahoe healey Adjustable steering tightening Austin Healey 13
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
G Adjustable steering Triumph 4
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
H Adjustable Steering Problem Austin Healey 4
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
P Adjustable Steering Triumph 2
GregW Adjustable steering wheel Austin Healey 13
WALTER adjustable steering Austin Healey 6
