Adjustable Steering Problem
Hondo Hernandez
Adj steering on my 62BT7 will not lock. The clamping nut turns to both extremes. When tight the steering wheel easily travels forward and back. Have not disasembled but don't see any broken parts. The dust cover and two caps are loose tho. Has anyone had this problem ?
Hondo
John Loftus
Hondo,
Looking at the wheel from the drivers position, you turn the nut counter clockwise to tighten. The nut simply tightens the splined collar on the wheel to grip the steering shaft. If it is not tightening perhaps the threads are stripped or the nut has separated internally. When you turn the nut does it move fore/aft with respect to the steering wheel?
Cheers,
John
Keoke
Hi Hondo, there has been some indication of this problem with aftermarket wheels.The problem seems to be that the splines on the wheel hub are simply not long enough or the apreture in the adjuster is too large.Consequently, when the adjusting nut bottoms on the hub the splines are not tightly clamped to the steering shaft.Using brass shim stock you may be able to shim the out side of the wheel's spilined part so that it will lock on the steering shaft.---Fwiw---Keoke
H
Hondo Hernandez
John,
Thanks for the reply. I just went out and turned it clockwise until it came loose then counter clockwise to the absolute tightest position and walla it is locked. Guess I didn't tighten it enough sitting behind the wheel. This time I was outside the reaching in......All these years with this problem duh !!!!
Hondo
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
D BT7 adjustable steering column / steering wheel Austin Healey 1
4tecdog Adjustable Steering how? Austin Healey 8
Lin Loosening adjustable steering wheel Austin Healey 3
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Crankshaft Adjustable steering column? Triumph 11
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
D Adjustable steering wheel stuck Austin Healey 6
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
K Adjustable steering wheel setup Triumph 2
longbridgehealey adjustable steering Austin Healey 6
tahoe healey Adjustable steering tightening Austin Healey 13
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
G Adjustable steering Triumph 4
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
P Adjustable Steering Triumph 2
GregW Adjustable steering wheel Austin Healey 13
WALTER adjustable steering Austin Healey 6
