dvu101 said:
I cannot get the big black lock nut loose.
I don't have a BT7, but I do have an adjustable steering wheel and I don't think that there are too many versions.
I don't remember any big black lock nut anywhere between the horn button and the front end of the steering box. What are you REALLY trying to describe ?
IF you are talking about the the bumpy, black, plastic ring between the back of the steering wheel and the dash that keeps the steering wheel from sliding forward and back, it's pretty easy, but there is a trick to it.
Unless you have VERY STRONG hands, get a proper strap wrench and while holding the steering wheel immobile, turn the bumpy, black, plastic ring <span style="font-weight: bold">CLOCKWISE !</span>
Because you are looking at the threads from the other end, it appears to be backwards from normal.
If you can get a grip on the ring and turn it CW, it should come right off.
If you really don't have an adjustable steering wheel, do what Keoke says....
Tim
