Adjustable steering tightening
A few months ago I purchased a new hub and "cullett" form Moss for my new steering wheel. I cannot get it to tighten so it wont go in and out on its own. Not a lot to wrong in there but I cannot figure out what is not holding. Should I put back the old cullett?
TH
steveg
If you're referring to the 'cullett' meaning the ringnut for the adjustable steering, mine's original and won't hold on the Moto Lita hub. The wire circlip is the only thing that holds my wheel onto the shaft.
It's humbling to contemplate fiery death held at bay by that heroic little circlip!
GregW
Platinum
If you think about it, that clip does <span style="font-weight: bold">absolutely</span> nothing to keep the column going into you. The clip keeps the wheel from moving rearward, but in an accident it would be like the wheel is moving forward if your chest impacted it.
tahoe healey
So, am I to gather that others have the problem of the wheel moving in and out? Moss has not had any other complaints recorded and wants to help if there is a problem. If you have one, call them and ask for Blaine. They will fix it if there is a defect in the system.
TimK
Mine is original and will not grab anything. It freely moves in and out.
Ed_K
I had a problem with the hub/collet that I got from Moss. It wouldn't fit over my existing shaft until I ground and filed some of the metal out of the new collet. It does grip OK when tightened and the wheel doesn't move but there is a little " play " in the fit. Some time after I retire and need a project, I'll take it back apart and replace the collet with a new one, ( hopefully by then the new ones will be made correctly ).
Ed
Stretch
A long time ago I put in a thin shim to help the pinch from my original steering wheel as the hub was tightened. Worked for years but just two weeks ago I noticed looseness again. I used a strap wrench before to get some extra torque. Be trying it again soon.
tahoe healey
There is a felt bush listed in my "mechanical service parts" book that appears to belong in that area that I do not believe I have in my steering unit. It is not shown in the Moss cat. Has anyone seen this on their steering assembly?
tahoe healey
No, Dave. The part looks like a long (3 inches?) tube with a slit along it. In my book, it appears in both the adjustable and non-adjustable steering systems. Part number is ACA 5297. It is shown at the wheel end of the shaft but not clearly where it should be placed in relation to the tightening nut (collet).
GregW
Platinum
Hi Rich,
The number you're referring to is a felt bushing. It goes inside the steering column. I looked in my shop manual, but I didn't see anything on exactly where it goes (and I can't remember). I'll check another book sometime today, but it doesn't have anything to do with the issue you have here. It keeps lube from dripin' in the driver's lap during hill climbs.
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
D BT7 adjustable steering column / steering wheel Austin Healey 1
4tecdog Adjustable Steering how? Austin Healey 8
Lin Loosening adjustable steering wheel Austin Healey 3
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Crankshaft Adjustable steering column? Triumph 11
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
D Adjustable steering wheel stuck Austin Healey 6
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
K Adjustable steering wheel setup Triumph 2
longbridgehealey adjustable steering Austin Healey 6
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
G Adjustable steering Triumph 4
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
H Adjustable Steering Problem Austin Healey 4
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
P Adjustable Steering Triumph 2
GregW Adjustable steering wheel Austin Healey 13
WALTER adjustable steering Austin Healey 6
