TR2/3/3A Frozen Steering Wheel [Adjustable]
RP3
Greetings,
I have an adjustable steering wheel that won't adjust. I'm unable to even turn the adjustment nut below the steering wheel.
Are there any suggestions on how to break loose the nut and steering wheel?
Thanks in advance,
Robb
Snowkilts
Don't touch it. The adjusting nut is fragile and irreplaceable.
I've owned mine since 1996 and never adjusted it. The adjustment really just takes a steering wheel that's already too close and makes it closer.
karls59tr
Bronze
If you really have to free it up soak it with PB Blaster ,give it a few raps with a wrench to set up a vibration to let the penetrating oil seep in. Let it sit overnight and in the morning carefully work the adjuster back and forth to free it up.
NutmegCT
Sounds like you have experience!
I use 50/50 PSF/acetone to loosen stuck nuts, etc. Been using that for over ten years.
Tom M.
karls59tr
Bronze
Tom M.
Interesting. I have a quart of acetone that's been sitting in the basement forever. I remember that it has a powerful smell? What dose PSF stand for? Maybe I'll brew up a concoction.:friendly_wink:
NutmegCT
Sorry - PSF = Power Steering Fluid. Here's a copy of the original article comparing different penetrants. Note that altho' the article says ATF, the photo shows PSF, which is what Mr. Bender actually used.
https://drive.google.com/open?id=1vEPEO4mZ-cnPTfsrBq_nDl3rC09WTXmW
Lots of discussion on this in various forums.
Tom M.
W Frozen fulcrum pin Spridgets 7
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
S BJ7 frozen temperature sensor to block Austin Healey 17
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
C Distributor shaft frozen, but why? Austin Healey 12
Csarneson Frozen Hinges Austin Healey 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
Sherlock A Chiva Bus for the frozen north Spotted 4
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
bugedd Frozen door hinges Spridgets 10
T Frozen head studs Austin Healey 11
RJS Frozen Caliper Piston Triumph 15
J Brake/clutch pedal frozen Triumph 18
F Frozen Clutch Prevention Austin Healey 10
wangdango TR6 '76 TR6 frozen clutch? Triumph 10
I TR6 TR6 frozen brass lower trunion Triumph 3
B Wire wheels: frozen knockoff Spridgets 13
K TR2/3/3A TR3 Lower Bump Rubber Bolt Frozen Like its Welded Triumph 5
R Disassembling frozen brake cylinders Jaguar 5
W Frozen Spring Bolt Removal Spridgets 17
B clutch frozen Triumph 8
PAUL161 Opening locked trunk with frozen lock & lost key MG 3
H Frozen Radiator Drain Tap Lever Austin Healey 6
1 Removing a frozen tie rod locknut MG 15
B Frozen Distributor MG 7
B frozen distributor on 69 mgb Restoration & Tools 3
J Winter Storage - In the Frozen North Jaguar 4
J Frozen E-Brake Spridgets 7
G T-Series Just bought MG TD;engine is frozen;suggestion? MG 13
M Frozen Bonnet Release Despite Warm Weather! MG 8
L Frozen Bolts on Leaf Springs Austin Healey 15
Sherlock Yes... we have some nice cars in the frozen north Other British Cars 9
G Clutch Frozen Austin Healey 27
L Releasing Frozen Nuts & Bolts Austin Healey 22
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
