bob hughes
Ok, here is the problem.
I have noticed that my adjustable steering wheel can be rocked slightly and with a good tug, I can telescope the steering without undoing the calmping nut, ie. things are a bit worn.
Whilst the engine is out I have removed the steering column so that the engine bay can be painted, I have examined the steering wheel and have come up with an idea how to solve my problems.
1) to stop the rocking motion, presumably due to the worn clamping nut or the bevel at the bottom of the boss, I have 'fashioned' ( small bit of filing) a narrow sleeve using a 20mm olive from my plumbing kit to slip inside the top of the steering boss and fit over the steering shaft splines, this prevents any movement at the top end of the boss.
2) to improve the clamping mechanism, I have resorted to covering the split bevel at the bottom of the steering boss with PTFE tape, this takes up the wear and appears to work.
It must be said that I have not yet tried both remedies in earnest yet
Has anyone else had similar problems and how have they been overcome?
Bob
Bob
