Hi Earl,
Like Geo, I'm not 100% certain what you are up to.
Please give us some more detail on what you are trying to accomplish and what parts you have to work with. Maybe we can offer more help.
I seem to recall previous post(s) where you mentioned having a complete TR4 live rear axle/diff assembly in your TR3, which would be 2" wider than the TR3 unit and I was concerned this would cause some problems with tire clearance, leaf spring mounts, etc.
So, are you replacing the entire rear axle/diff assembly? If so, those special tools might not be needed at all. It's simply a matter of unbolting the drive shaft and the u-bolts at the leaf springs, removing the limit straps that go over the axle tube on either side, removing the axle shaft/hub assemblies from either side and then sliding the remainder out from under the car. All this can be done without special tools.
Or, are you disassembling the rear axle/diff to take the diff itself out of the axle, to make some sort of swap of internal parts or to replace bearings and seals? If so things get quite a bit more involved, but Geo is right that there is no need to use a hub puller for this job (a diff case spreader might be needed, though) unless you are changing the outer, rear axle bearings and/or seals. As Geo mentionied, there are bolts (6 per side actually, Geo, on TR4s) on the backside of the brake backing plate that can be removed to allow hub and axle to be pulled out as a unit. Some precautions: Care must be given to keeping the sets of shims behind each brake backing plate in order (these set the axle end play, which needs to be correct and equalized side-to-side), and when sliding the axles in or out be careful not to damage the seal in the axle tube. Also, be a bit careful handling the hub/axle shaft assembly when it's off the car, especially the splines on the end that mesh to the differential itself.
But, let's step back a moment and look at the bigger picture. You're working on a TR4 axle assembly/diff, right? I see no reference to those Churchill tools in the TR4 workshop manual. I *do* see reference to S125 in the TR3 workshop manual, but it appears to be a special tool to *install* the splined hub for wire wheels and unique to certain, later TR3. A different tool is used to remove the splined hub, but isn't needed at all on TR4. So, part of the problem might be consulting the earlier manual to work on the later live axle assembly?
Just so you have the numbers, Churchill M86 or M86A is the tool to separate the TR4 rear hubs from the axle shafts (it's possible to do in a 20 ton press, as mentioned, but some hubs get damaged in the process). Churchill S101 is the case spreader tool, used to remove the differential assembly itself from within the diff housing (it's possible to make this tool from materials from a hardware store, however I need to caution that it needs to be used carefully to just slightly spread the diff case, overdoing it can bend or crack the case, and some folks manage to get the diff out without this tool). These are probably the two most necessary tools for work on the TR4 live axle assembly, but are only needed in certain circumstances. There are other special tools needed for work on the axles and diff, but they are more commonly found or "generic" items like a dial test indicator, bearing pullers/installers, etc.
If you are removing the differential itself, for some sort of internal parts swap, getting everything reinstalled and setup properly in terms of tolerances, preload and crown wheel/pinion gear mesh, etc., etc., is quite an involved and precise job. I'd not recommend it for most folks to try at home. Often the best local source for this sort of work is a heavy truck repair shop, since many trucks still use live axles similar to the old TR design.
P.S. There is a company that might be useful with some Churchill tools.
https://www.britishtool.com/ used to be an advertiser here on BCF, but I don't see them right now. Good folks, but they didn't offer the M86 hub puller I needed, last time I checked with them.
