TR2/3/3A tr3a large manifold clamps: where the heck do they go??
2billydavies
hi everyone... finally got my TR3a shipped from PA to FL. Quick question: the large manifold clamps: where the heck do they go?? I know where the 4 smaller clamps go, but for the life of me, I can't figure out where these 2 large ones go or what they hold down. I"m sure its right in front of my face, but I can't figure it out. any help sure would be appreciated. i'm pulling what little hair I have left right out of my head! Thanks!
Geo Hahn
They are for the two centermost studs under the manifold.
On mine the those studs are long enough that I have to fit the clamp (and lock washer and nut) before the manifold is fully home against the head -- otherwise there isn't enough room between the end of the stud and the manifold to get them on.
TR3driver
Great Pumpkin - R.I.P
The big clamps go underneath the intake manifold, between the carbs. Sorry I can't find a good photo offhand.
As I recall, you have to first place those two bridge pieces and start the nuts over them before you slide the manifolds home against the head and install all the other hardware. When you do slide the manifolds home, make sure the intake fits over the dowel pins in the side of the head. You may have to lift and/or wiggle things to get it over the pins. What you don't want to do is try to force it over the pins by tightening the nuts (otherwise you'll have a leak).
Oops, I see Geo beat me to it. I wasted too much time looking for a photo :smile:
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 0
Hamish Racing TR2/3/3A TR3a track fun in uk Triumph 2
F TR2/3/3A TR3A tub assembly Triumph 44
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 1
D TR2/3/3A TR3A electrical issues Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Hamish Racing General TR UK SPRINT RACE in my TR3a Triumph 5
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 6
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
Donald1107 59 TR3A Fuel Pump Triumph 48
D TR2/3/3A 1961 Triumph TR3a Triumph 17
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
60TR3A TR2/3/3A How To Jack Up a TR3A Triumph 14
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
S Price check on TR3A valve cover Triumph Classifieds 0
G 1962 TR3A inner plate # Triumph 8
G 1960 TR3A for sale $9,999 or best offer! Triumph Classifieds 3
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
71TR6 For Sale TR3A Roll Bar for sale Triumph Classifieds 1
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S Wanted Wanted - TR3A Horns Triumph Classifieds 2
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
K For Sale TR3A Steering wheel Triumph Classifieds 4
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
T For Sale Tr3a 1961 Triumph Classifieds 0
S TR2/3/3A Need New Battery for TR3A Triumph 7
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
D Wanted TR3A starting handle Triumph Classifieds 0
T TR2/3/3A TR3A Door Handle Triumph 3
W TR2/3/3A TR3A Movie Sighting Triumph 8
D TR2/3/3A TR3A Crank Dog Triumph 2
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
J TR2/3/3A TR3A gas tank repair Triumph 4
