what grade oil
ramajon
Member
just purchased healey 100-six yea a bit hard starting like my bugeye.. the oil looked a bit low and dirty so i was wondering what grade people are runnung in thier 6 cylinder motors
jlaird
Bugeye hard starting? Should not be. Drove one to work everyday for 28 years, never a miss and always started first pull.
Somethings wrong.
Keoke
Hi Ramajon,It appears that a good grade of 20/50 oil is what most prefer to use in the cars.---Fwiw---Keoke
MadRiver Multi-grade oil in gearbox? Austin Healey 2
Rut Grade 9 bolts Spridgets 6
Rut MGB Grade 9 bolts MG 4
Rut TR4/4A Grade 9 bolts Triumph 6
sim 58 sprite suspension up grade or not Spridgets 25
KVH Grade 8 Bolts Triumph 7
I Suggestions for drilling a hole in a grade 8 bolt? Triumph 24
I Internet source for grade 8 bolts? Triumph 12
T Sourcing Grade 8 bolts..... Triumph 23
19_again grade 8 nuts on ?grade studs MG 14
I rear axle to differential flange bolt grade? Triumph 8
Tinkerman Grade 5 or Grade 8? Triumph 13
hondo402000 alternator up grade and smoking dash Triumph 19
W What grade of gas/petrol ?? MG 17
A TR6 Up-grade to 1/2" lug bolt, which ones??[tr6] Triumph 7
M TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!! Triumph 4
hondo402000 TR6 alternator up grade for 71 TR6, what works Triumph 8
V New Grade 12.9 Socket Head Bolts Triumph 2
I Best bolt grade for Triumphs Triumph 20
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
T Where to buy Factory Grade Paint? Triumph 6
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
