Hi,
As noted, McMasters Carr online is a good source of hardware.
Also check near your local airport for a parts vendor, who will often have aircraft maintenance hardware. Aviation quality fasteners (AN) are good to use for some highly stressed applications (drive shaft nuts & bolts, for example, where all-metal/self-locking nuts, grade 8 or better, and bolt shank length are all very important).
Another online source is
www.boltdepot.com They have some good, general reference info there, too. An advantage they have over McMaster-Carr is that Bolt Depot offers small quantities at reasonable prices. Many places don't. (What the heck am I gonna do with 100 Grade 8 SAE 5/16 x 2" bolts?)
Something not yet discussed is correct fitting of nuts & bolts in higher stress automotive applications. The idea is to use proper shank (body) or unthreaded area length, so that no threads end up located within the holes. The reason is that during normal running vibrations will cause threads within the holes to act like a milling machine, eventually enlarging the hole and loosening the fastener. If you look at many original fasteners on TRs, you will find that Triumph paid a good deal of attention to this in most applications, especially throughout the drivetrain and suspension. One place they didn't is the lower/front generator mount at the front engine plate, and that's very commonly badly worn oversize.
Another fitting procedure that's important is to see that there are adequate threads so that 5-7 full turns are within any nut. Too few makes for a weak joint.
Airframe or AN bolts are sold by the length of the shank and usually available in 1/8" or 1/16" increments, allowing far more accurate fitting than typical Grade 8 or Grade 5, where shank length is pretty uniform but in large increments (say 1/2" or so).
One or two washers can be used to adjust shank length slightly. If necessary, extra thread length can be trimmed off. I often use a Dremel tool with a reinforced cutting wheel for this. It works well. Try not to overheat a bolt when cutting the length, though. That might remove its hardening. In most cases, it's not a good idea to use a die to cut more threads to a shanked bolt... For one thing, Grade 8 is pretty hard for this and will quickly dull dies. For another, cutting more threads can weaken the bolt.
There are also low-profile nuts and bolts, and reduced size heads, for tight applications.
In terms of locking - I agree that using Locktite is a good practice. There are several types available. Medium strength works well for many applications. High strength often needs to be heated to release, so take that into consideration. Some locations simply make it difficult or impossible to heat the fastener with a torch even momentarily to loosen high-strength Locktite. In other locations, it's ideal.
Split ring locking washers can be used, but should be replaced after one or two uses. Split rings do not work well in combination with flat washers. All the other locking methods listed below work well in combination with flat washers.
Speaking of which, in restoration projects, I like to add extra flat washers in a lot of locations, to help spread the tightening load out a bit on the old parts, just in case there is some fatigue.
For locking, Nylock nuts work well, but should only be used once. Most widely available Nylock nuts are at best Grade 5. Grade 8 is available, but harder to find and a whole lot more expensive.
All-metal self-locking nuts are better and can be reused a few times. These are often referred to as "aircraft nuts".
Castellated nuts with cotter pins and stainless steel safety wire are about the most secure arrangements, overall. But, Grade 8 can be a bugger to drill for safety wire!
A side note regarding stainless steel fasteners, some screws I bought from a local hardware store recently are really bad. They are phillips head and strip super easily with a power driver, snap off easily and I notice the shards are sticking like crazy to the magnetic screwdriver tip (stainless is usually largely non-magnetic, or so I thot!). Still, the are simply wood screws being used to hold a trim/seal around a garage door, so will do the job. Just watch out for the quality from many hardware stores. If it's "only" 2X or 3X the price of regular steel stcrews, I'd suspect the quality of any S/S screws might be substandard.
