hondo402000
took the 6 out for a drive and smelled burning plastic, got back home quickly and started watching and noticed smoke from under the dash. the wires connected to the amp gauge were hot and the source of the smoke. I installed a 55 amp alternator and some of the direction said to run an additional heavy gauge wire directly from the alt to the battery Pos terminal. I had done that but didnt hook it up. While driving at night with all lights on, radio blasting the amp gauge was basically full scale charging. when I hooked the wire to the pos terminal from the alternator the meter goes back to center and the smoked stopped and now all is well. Moral to the story, if you put a high capacity alternator, better run a 8 gauge wire directly to the battery pos and no have all that current going throught the amp gauge
