TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!!
MDCanaday
If you ever wanted to use your OE cleaners for something besides shows, here it is! Write it down,buy it cheap, JohnDeere # M 96846 filter element fits like a glove over the outside of the old AC unit and actually removes dirt from the air!!!Not just june bugs! Slip it on for go, slide it off for show. Cleans in a snap.$3.30 each.. sound like a deal??
MD(mad dog)
sammyb
Do you wash these thoroughly in Petrol every 3,000 miles? /ubbthreads/images/graemlins/wink.gif
Harry_Ward
John Deere lists it as a filter element - foam. I assume it is the foam prefilter which wraps around the metal/paper air filter. We usually wash them with soap and water and then blow them off with compressed air. Then depending on the application we emmerse in clean oil and wring out all the excess. For the 3 I would leave it dry if it is to be wrapped around the existing air filter. If you emmerse in oil it will remove more particulate but it will definitely change your intake fuel/air mixture .
M
MDCanaday
This is an oiled -foam type filter that should let the old ac be useable for most driving(not on gravel??)I have not put any miles on this setup yet, but if cleaned and oiled when dirty it should be the ideal show & go air filter with no points off at concourse. It should NOT change the mixture unless very dirty.
MD(mad dog)
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
G For Sale TR2 TR3 TR3A TR3B Unrestored Hardtop with Window, New Hardware kit and Seals $1500 Triumph Classifieds 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
Rhodyspit75 TR2/3/3A TR3 & TR2 parts Triumph 0
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
AngliaGT TR2/3/3A New Windshield for TR2,TR3 $150 Triumph 2
mountainman TR2/3/3A TR2-TR3-TR3A Top Question Triumph 12
HerronScott TR2/3/3A Cutaway TR2-TR3? Triumph 1
beaulieu TR2/3/3A This time the TR3 is one, or maybe a TR2 ! Triumph 12
gsalt57tr3 TR2/3/3A TR2/TR3 grill surround on eBay Triumph 3
TRJohn TR2/3/3A TR2 TR3 master cylinders Triumph 2
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
P New member TR2 carpets Triumph 7
S TR2/3/3A Tr2 hood Triumph 8
W TR2/3/3A TR2 wiper motor mount Triumph 1
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
C TR2/3/3A TR2 Chassis Clips Triumph 4
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
P TR2/3/3A TR2 color questions Triumph 23
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
R TR2/3/3A TR2 Scam Triumph 13
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
M General Tech TR2 Slave cylinder Triumph 0
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
G TR4/4A TR2-3B Hub Extension Triumph 6
D TR2/3/3A TR2/3 Mille Miglia eligibility? Triumph 12
CJD TR2/3/3A Recipe for a TR2 Triumph 196
CJD TR2/3/3A TR2 Seats Triumph 26
R Wanted TR2 brakes Triumph Classifieds 8
CJD TR2/3/3A TR2 Boot Strip Triumph 22
C TR2? Special Racing 3
CJD TR2/3/3A TR2 Wing Beading Triumph 24
