speedometer cable and housing
wdp
I'm about to install a new cable and housing for the speedometer in my 72 BGT. Do I need to lube the cable first or does it come pre-lubed in the new housing?
Nunyas
a little lube wouldn't hurt I suppose. The last cable I got from Moss Motors was not lubed.
tony barnhill
Great Pumpkin - R.I.P
Don't know that I would use a liquid but instead would use graphite.
Steve_S
Graphite powder is good, sure. I typically use a very light oil like Tri-Flow because it seems to last a little longer and helps prevent rust on the cable.
jlaird
Wipe it down with a light oil.
Never assume that parts come pre lubed.
W
wdp
Ok, graphite powder or a light oil. Thanks for the info everyone.
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
P TR6 Jumpy Speedometer cable Triumph 4
M TR4/4A Speedometer Cable Routing Triumph 7
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
S BJ8 Speedometer Cable Austin Healey 6
S Speedometer Cable Spridgets 5
P TR6 speedometer cable Triumph 21
R TR2/3/3A TR 3A Speedometer Cable Route Triumph 12
C routing of speedometer cable on BN6? Austin Healey 11
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
C TR2/3/3A Speedometer cable fastener locations Triumph 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
K TR2/3/3A Speedometer cable fittings? Triumph 4
B TR6 Brand New Speedometer Cable breaks Triumph 5
Patrick67BJ8 Speedometer Cable-5-speed Trans Austin Healey 6
R Smitty Speedometer Cable Fix Austin Healey 1
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
G TR4/4A tr4a speedometer cable Triumph 9
angelfj1 Speedometer [cable failure] and repair Triumph 5
J TR4/4A TR4 Speedometer cable routing Triumph 0
longbridgehealey Speedometer cable not spinning Austin Healey 15
T Quesiton on A-type OD speedometer cable fitting Triumph 12
D speedometer cable Austin Healey 17
T TR4/4A TR4 Speedometer Cable Triumph 3
bcbug Another speedometer cable replacement question Spridgets 4
bighealeysource T-Series Stuck speedometer cable on TC MG 3
J Speedometer cable issues? Austin Healey 7
V TR2/3/3A TR-3B Speedometer Cable Triumph 6
gubba speedometer cable right angle adaptor Triumph 4
TimK Speedometer Cable Routing - BN7 Austin Healey 2
JPSmit speedometer cable question Spridgets 8
Sarastro Source of a good speedometer cable? Spridgets 5
S Speedometer Cable Installation Problem Austin Healey 5
Magyar Speedometer and cable Spridgets 5
S Lubricating Speedometer Cable Austin Healey 13
T Speedometer cable Triumph 0
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
walshja speedometer cable Spridgets 9
S TR2/3/3A Speedometer cable tr3 Triumph 3
C speedometer cable issue MG 2
T Speedometer and cable Triumph 2
HEALEYJAG 100 speedometer cable routing Austin Healey 5
I TR6 TR6 speedometer cable Triumph 3
Rob_P Speedometer Cable MG 7
AUSMHLY Speedometer cable length Austin Healey 4
T Broken Speedometer Cable Triumph 5
