bcbug
Replacing the 3 part cable on a 76 with a 1 piece cable. I purchased a one piece cable that goes on a 78 midget. Top end has typical screw on fitting for the back of the speedometer. The lower end has a cone shaped rubber boot with the end of the cable sticking out about a 1/2". The drive pinion on the transmission also has a piece of cable, which looks just like the end coming from the cable. What connecte these two male ends togather? is there some sort of sleeve which fits between the two ends that connects the togather? I expected to see another screw type arraingment on the lower end like the top end but this threw me a loop.
