Hey Guest! Yoda says: A FREE resource for the Little British Car community BCF is. Support us with an account upgrade, not many will (less than 1%) "Require" you to pay to play we don't, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Supporting us with an "optional" low-cost member upgrade you should. There are some benefits to upgrading!
Did you check the driven gear at the end of the cable in the transmission? Have found many that get stripped or plugged with debris.
Be sure to count the correct number of teeth.
If you haven’t solved your speedo cable issue or gotten one from Bill at Dominion, you might try Vintage British Cables up in Vancouver BC. They have an M cable and can make up cables with all their parts. Google the name.
