running way too hot.
Will_Ringrose
Alright, it seems like the last few weeks have been a nightmare for me.
Electrical fire- Fixed wiring
Alternator died - GM swap
Now the thing is running way too hot. Just at idle it will get nearly in the red. When just a few days ago it would just barley get above 3/4 at idle. And when driving it would be just a hair over 1/2.
The timing is good, The pump is working. What do I check next?
Andrew Mace
Get whatever kind of thermometer (infrared, candy or other kitchen thermometer) and see what the actual coolant temperature is. With all the wiring and related problems you've had, it wouldn't surprise me if something is amiss with the gauge sender or the voltage stablizer for the temp and fuel gauges, or related wiring?
Or, you could actually have a cooling system problem. But confirm the relative accuracy of the gauge first!
Brosky
Don't get mad, but the belt is tight from changing the alternator, right? Thought so, but had to ask.
First check coolant level. Make sure no leaks or air pockets.
Next, check thermostat. Take it out, cool it down and then drop it into a pot of boiling water and see if it opens all the way.
Good time to flush the system and add 50/50 mix for winter.
tinman58
Double or triple check your timing!! If I did, it would have saved me from removing apron, radiator, head,water pump, etc. Catch my drift?
W
Will_Ringrose
looks like I have a long day in-front of me tomorrow. I will just replace the thermostat, I have a nice little digital thermometer that I use to use for Tea. I will get the car up to temp and check it.
I assume the Voltage stabilizer is working well because my gas gauge seems to be doing just fine.
Should I take the time and flush it all out to make sure there is not a blockage?
On the GT6 motor i have every number been thrown out at me for timing. I currently have it set at 8 after.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Should I take the time and flush it all out to make sure there is not a blockage?
On the GT6 motor i have every number been thrown out at me for timing. I currently have it set at 8 after. [/QUOTE]
Yes, drain, flush and replace and it's done once and for all.
And PLEASE tell me you mean 8 degrees BEFORE TOP DEAD CENTER,
NOT AFTER TDC.........if you are after, there is your overheating, starting and running like a pig problem.
TR_Jim
If there is no vacuum retard, (mine didn't have one)I ran 8 degress BTDC.
Brosky
Actually, I'd make it 10 BTDC, with the retard or advance unit disconnected, the engine warmed up and at 850-900 rpms and the vacuum line from the carb to the dizzy plugged.
Andrew Mace
Is that static timing with engine off, or is that "dynamic" timing at the "proper" idle speed as per underbonnet sticker?
I ask, because the factory workshop manual states that, for "emissions controlled vehicles" 4 degrees ATDC at idle, which is approximately 6 degrees BTDC "static" timing.
TR3driver
Great Pumpkin - R.I.P
That's strange. The 73 emission system training notes say that for a GT6 MkIII, 4 ATDC at idle should be 12 BTDC "static".
The difference of course is the action of the vacuum retard module. If your module is non-functional or disconnected, then you should use the 12 BTDC number. And especially if you are having overheating problems, I would suggest disconnecting or disabling the vacuum retard.
Another thing to check while you've got the timing light hooked up is that the centrifugal advance is working. Just rev the engine up somewhat slowly, while watching the timing mark. It should advance smoothly up to about 4000 rpm. Total advance @ 4000 should be 32 degrees (all according to the training notes). But I wouldn't worry about checking the exact value, just that it moves smoothly and falls back when the engine rpm is let back down.
Andrew Mace
Ah, semantics...and the ever-present common language that separates the UK from the US!
Yes, there is also a figure given in the workshop manual for "ignition timing -- conventional -- static"! That is 13 degrees BTDC for the ["Mk1"] GT6, 10 degrees BTDC for the GT6+ and 12 degrees BTDC for GT6 Mk3 (USA MARKET).
TR3driver
Ah, well, Will says he has a 73 GT6 and lives in the US (presumably making it a US market car), so we should probably quote the numbers applicable to his car.
And even 6 degrees slow on the timing can cause the engine to run hotter.
Andrew Mace
Which is exactly what I did!
Agreed!
poolboy
I'm guessing that the reason for not worrying about the exact value when observing the advance with a timing light is because you think that the damper marks may no longer be accurate ?
angelfj1
Will: Looks like you've received some great advice here! Let me add something that I do each fall when I flush and refill my coolant. I disconnect the heater from the cooling system first. Then I proceed in flushing the engine and heater separately. That way crude from the engine doesn't get forced into the small tubes in the heater core and vice versa.
Good luck!
Kim de B Running too hot up grades at speed MG 28
J TR2/3/3A TR3A is running too rich Triumph 4
Jim_Gruber Running too warm at sustained high speeds Spridgets 5
J Healy speedometer is running too fast Austin Healey 6
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
G Running too cold... Triumph 1
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
