TR2/3/3A rough running after 20 min shutdown
TFB
My TR3 runs great,no issues except one.
On a hotter day say over 80 if I shut the car off and then restart after sitting about 20-30 min. the car starts up easy but wont idle and runs rough for about 30 seconds and then goes back to normal smooth idle.If it sits longer it doesnt happen.If I shut the car off for few minutes it doesnt happen.
Today I came home let it sit about 20,same symptom.Water temp gauge crept from 185 to 200.Infared temp gum showed intake manifold 170,float bows about 115,I pulled off one bowl top and fuel was about 3/4 full.I think gas may be vaporizing or flashing until the manifold cools down but not sure.
Any input appreciated.
Tom
NutmegCT
Problem occurs only after a short shut-down when the engine is hot.
I'm thinking *vapor lock* due to engine bay heat vaporizing fuel in the lines near the carbs.
Quick check might be putting a wet cloth onto the fuel lines when this happens; that should condense any vaporized fuel in there.
Hope this helps.
Tom M.
CJD
+1...mild vapor lock. The fuel boils out of the lines, so you are starting on what's in the bowls. It runs rough until enough fuel passes into the lines to cool them and refill the bowls.
T
TFB
Thanks for replies.
I was thinking not the lines but manifold and cyl. head temp because bowl seemed pretty full.I will do some more experimenting with keeping the lines cool.I have a stock ex. manifold partially wrapped along with the pipe,steel line from stock pump to rubber fuel hose from just before the rad. neck to the bowls .I dont think its normal in 80 deg.Maybe Im a little lean.
Thanks
Tom
Madflyer
OK mine is a TR6 but, so more heat. I added heat shield at carbs replaced rubber gas lines with braided lines and add a screen door spring over gas line from fuel pump around head as cooling fins
T
TFB
Maybe a little too rich for restarting a hot engine.
Thats an interesting possibility.The car runs great,always starts with just a push of the buton,good plug color no pinging etc.
I need a little choke for about 1 min. from cold star to smooth no choke idle in even 70 deg. garage temp so I dont think thats the case but some more troubleshooting is ahead.
Thanks
Tom
NutmegCT
Tom - try the wet cloth suggestion in my first post. That should tell you if there's vapor lock going on.
I think that too rich/too lean would be indicated by plug appearance.
T
TFB
Thanks,I am going to try that .Hopefully getting out again soon.
Tom
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
N Stuck Needle Valve - Rough Running Austin Healey 15
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
B Thoughts...rough running at cruise. Austin Healey 3
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
A rough running after long idle or long low rpm driv Triumph 1
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
tahoe healey surging and rough running Austin Healey 20
K TR2/3/3A TR3 Running rough..Cam or Carbs?How to diagnose? Triumph 10
H MGB-GT Help with my 1967 MGB GT running very rough MG 5
R TR6 Rough running TR6 = Pertronix? Triumph 27
Woodie rough running Spridgets 7
S TR2/3/3A Rough Running TR3A - help with diagnosis Triumph 11
A TR4/4A TR4A running rough question[s] Triumph 11
Woodie missing, running rough etc etc Spridgets 25
J running rough / missing Spridgets 7
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
77MidgetMkIV Now running really rough-help?!?! Spridgets 15
beebopbogo Engine running really rough - 2 cyls? MG 8
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
C Rough Idle - What to check? Austin Healey 12
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
M TR2/3/3A Engine rough on acceleration Triumph 19
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
M Rough Idle MG 15
K Rough patch inside bore of SU? Triumph 2
W Mighty rough..... Spridgets 1
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
B diamond in the rough? Triumph 6
