Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up
Josiah
I bought this car about a year ago. I did a tune up about a month ago (new plugs and air filter and oil change). The old plugs were pretty black so I believe the car was running rich. The car ran great with the new NGK Iridium plugs. Was able to take it out about 3 or 4 times. I took the carb apart (Weber 32/36 DGAV switched over to Electric choke by PO) to clean it up and check the float height. When putting it all back together I realized one of the fuel lines was leaking where the clamp was. So I replaced it. At that point I realized where that fuel line went..... So the Weber DGV has two input's, one for fuel line and one optional one which everyone typically just plugs off. Well the PO (previous owner) had a line coming off of the option inlet and going to my Charcoal canister...……. When I replaced that line and started the car yeah it didn't leak anymore but it flooded my Charcoal can and fuel was just pouring out of it...… So I plugged that optional fuel inlet off. And I now only have the crankcase vent and the breather coming off my carb hooked up to a T and running to the charcoal can and my gas tank vent.
So I thought I had it all correct now. Well now my car just sputters and pops (exhaust) when you start it. And if you try and rev it up you can feel the restriction in the exhaust system (running straight pipe). After about 3 minutes or so of running very rough it starts to smoke down low past the headers somewhere... I just turn it off once it starts to smoke. The motor runs rough (shakes violently). I'm at a loss... Feels like the car is missing?? Like the timing is off. It has an pertronix electric distributor and flame thrower coil (they look fairy new). I havnt driven it since it has ran this bad.
Does anyone have any ideas...……………….
Thank you
pdplot
Bronze
With my limited knowledge in general and no knowledge whatever of Weber carbs, it sounds like the electric choke may not be releasing. Try disconnecting it and see if that makes a difference. What else did you do before it started running bad? You probably did something to make your engine unhappy. I hope that better minds than mine will give you some other ideas but I would start with that.
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
N MGB 1979 MGB exhaust replacement. MG 1
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
A MGB 1979 MGB Flasher Big Headache MG 3
AngliaGT 1979 B Owner's Manual MG 6
T MGB 1979 MGB with Weber carb MG 6
R MGB Testing temp sending unit 1979 MGB MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
B 1979 MG Midget Headrest Available! Spridgets 3
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
C Triumph colors from PPG book 1979 Triumph 2
I 1979 wont go into reverse MG 10
H Geoff Healey @ Encounter 1979 - 8trac tape Austin Healey 9
C MGB 1979 MGB Photos MG 6
G Good ideas for 1979 MG B MG 2
