Placement of studs on 4.2 Jag engine
sacat
My brother removed the studs on the engine for replacement after removing the head. He did not mark them for so he would know where to put them back.
HELP!!!!
Platinum
It'd be good insurance to replace the studs unless they're in REALLY good shape (NO pitting or corrosion at the bottoms). One stress riser on one stud and you'll be doing the whole job over again... with some added grief in-between. If one breaks down in the block there's no easy way to get the "stump" out. BTDT.
Just my 2¢ worth.
beachbumbarry
I have the head off of one of my 4.2s and could take some pictures if you think that it would help you. I will also replace the studs during the rebuild. I also have an extra 4.2 that is complete 2 carbs, starter, alternator etc. If you know anyone that needs one beachbumbarry@msn.com
BarryE
S Placement of Studs on 4.2 jag Jaguar 2
D TR2/3/3A seat runner placement Triumph 1
Twit TR4/4A Placement of OD relay Triumph 3
Lin Electric Relay Placement Austin Healey 11
Rut Bugeye 1275 temp probe placement. Spridgets 8
maxwedge5281 side curtain felt placement in channel Austin Healey 4
I TR6 Mirror placement Triumph 4
Gliderman8 TR6 Fire Extinguisher placement Triumph 6
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
R jack/jackstand placement bj7 Austin Healey 18
5 Speaker Placement Spridgets 10
GTP1960 TR2/3/3A TR6 overdrive filter /magnet placement?? Triumph 18
L Gauge placement Austin Healey 2
I Bigeye fuel filter and placement recommendation? Spridgets 8
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
G Bullet Mirror Placement Austin Healey 24
R correct jack stand placement. Austin Healey 26
I TR6 Windshield washer jets...placement and installation Triumph 1
doughairfield TR4/4A Steering rack placement Triumph 2
G MGB Placement of jack stands MG 4
Tinkerman TR2/3/3A Dip switch wire placement Triumph 2
BwanaJoe TR6 Evaporative piping placement Triumph 6
I TR6 Horn placement Triumph 4
R battery placement Austin Healey 4
PatGalvin Scuttle Vent Rubber placement Triumph 4
J TR6 Fog/Driving Light Placement on 73 TR-6 Triumph 2
W hd 8 red green spring placement Austin Healey 1
brgrmyster GT6 Original speaker placement - 68 GT6 Mk 1? Triumph 10
J TR2/3/3A TR3A rear view mirror placement Triumph 13
glemon Fuel Filter Placement Triumph 13
G TR2/3/3A Threaded rod to Assist TR3 Tub Placement Triumph 6
I Bugeye decal placement help Spridgets 2
Hoosier MGB British Leyland cast logo placement on MGB MG 19
I Antisway bar locator bracket placement? Spridgets 2
glemon TR5/TR250 TR250 Starter Motor Placement Triumph 4
S TR2/3/3A speedo and tach placement tr3 Triumph 5
L Water temp sensor placement [secondary] Spridgets 7
Tinkerman TR2/3/3A TR 3A Accelerator Bushing Placement Triumph 21
L O2 sensor placement Spridgets 5
V Jack placement? Spridgets 4
T Windshield placement Spridgets 14
T 73 midget line placement Spridgets 9
JPSmit seat placement suggestion Spridgets 27
S Healey jacking points and jack stand placement Austin Healey 13
I TR6 TR6 speaker placement? Triumph 5
Gliderman8 Antenna Placement Restoration & Tools 11
jjbunn Gauge Placement - ideas? Triumph 24
RTR52nd Speaker Placement Triumph 5
RTR52nd Speaker Placement MG 2
Brosky Placement of temp sensor for cooling fan Triumph 33
