V
vagt6
Lotsa questions here, so thanks for bearing with me!
Jacking up a MKIII Midget: I placed the jack under the front frame cross member in front: is this okay?
And for the rear, the Haynes manual says "near" the differential near the spring attachment points. Does this mean "ON" or under the diff, or next to it?
I'd assume I place jack stands on the frame members on either side of the engine up front. Where in the rear???
I'm performing a blitz routine maintenance on the car this weekend; total lube, change gearbox and diff oil, adjust rear brakes, etc., etc.
Gotta get the car on jack stands.
Thanks!
Thanks!
